Quick Clutch Problem. I have searched
wackawacka
Background - I have a red top sr. My car was converted from auto to manual. I have all new master + slave, plus braided steel line.
Story - I drove my car across town yesterday. All was normal. Ran great. I got back home and parked it. Sister called for a ride. I got in car started it up, depressed clutch pedal and (attempted) to put it in reverse. Clutch is not disengaging and grinds even if i have pedal fully depressed. There is full normal pressure on the pedal and the slave is pushing on the fork. We plan on pulling off trans to replace stock clutch. Does anyone know what this problem most likely is? Thanks.
1sikS13
Car: 1992 S13 240sx
clutch is obviously not disengaging. Along with slave master and line you should have replaced the clutch also. start there report back to us. dont forget to replace throw out bearing and pilot bearing just so you know its not related
wackawacka
I never replace master/slave. Just installed because of manual swap. Clutch is being replaced. Wanted to know if it is something else like broken fork pivot.
nissans13240sx
Car: 90 R32 GTR
91 Hatch SR20
93 Coupe KA-T
04 STI
giggly pins, or CV BOOOOOOOOOOOT.
RyanAwesome
Car: Murdered out coupe.
Sounds like the fork isnt being pushed all the way in. Maybe some air in the lines or a weak slave. Bleed the clutch out again. Also see if the fork moves through the full motion.
nissans13240sx
Car: 90 R32 GTR
91 Hatch SR20
93 Coupe KA-T
04 STI
It moves all the way out. I have checked it out.
wackawacka
Disturbingly mysterious update: Went to try it again. Works fine. Im glad its working again, but scared to know when it will act up again. This is some Twilight Zone® sh1t.
RyanAwesome
kill it before it strikes again.
wackawacka
Oil level looked good. Hydraulic fluid level looks good. Im starting to think that I was having serious mental issues for that 10 minutes I experienced this. Its bizare.
Emperor_Tha
i had a problem with mine. all the gears work except reverse one day. then the next day i couldnt get out of 3rd gear. i took the trans apart and the fork broke inside the transmission. i believe the megan short shifter cause this becuz the plastic pushing got worn out so i would grind sometimes into gear.
