nissanfreak12 »
https://forums.nicoclub.com/nissanfreak12-u177688.html
Sat Nov 10, 2012 8:19 am
Check your timing again. It is very possible your belt jumped. This will cause a no start, but running, no power, etc.. You cant just rely on the lines on the belt or the marks lining up. If you read in the FSM you need to count the cogs, the marks are just reference points, they are not going to line up perfectly when all is said and done.
The other option is to check the injectors again. Yes, I know they ohm test and click, sometimes that does not mean anything, I had one go out, it clicked and tested good. I even had it flow tested, but for some reason it didn't work while in the engine. Replaced it with a new one, boom, car runs great. But you did say the plugs are wet? If the ALL are, then your only problem left to run is timing or ecu.
