It is a 1991 300zx, 2+0, 5 speed, T-top, 1 owner vehicle, and has been in texas all of its life. Vehicle runs like new, and has a laundry list of maintenance that has been done since 1991. It is in the best shape of any Z32 I have seen in person, except for the fact it was hit by a drunk driver in the front before I purchased it. My question being, what is going to be the easiest way to fix this damage? My plan is to purchase a TT front clip and do a full overhaul / build of the engine before installing. Is it possible to weld in the new TT front clip, or better to just swap all parts that I need? Extent of the damage is the fenders, driver side headlight, hood, headlight housing, bumper, bumper support crash bar, radiator upper support, and radiator. The pictures attached are before I tore into the car, since then I have removed the other fender, bumper, bumper support, and radiator fan shroud, with the shroud out of the way the engine starts and runs shockingly well, radiator pukes fluid from a hole, and obviously the airbag light is from the sensor being disconnected but the airbag didn't deploy shockingly. I will upload pictures of the damage found after removing the exterior parts later today.
- The underside of the chassis, lower radiator support, and frame have no damage, alignment still shows within specs, and vehicle drives straight shockingly.
Any advise or insight as to how to go about fixing it is greatly appreciated, I have an extensive technician background, have access to any tools needed, and have access to a bodyshop through Infiniti since I work here if needed, but I would prefer to do all work myself.
