zer0c123 »
https://forums.nicoclub.com/zer0c123-u10125.html
Sat Apr 22, 2006 10:08 pm
Well the smog tech was the one that cleaned it out. I failed smog twice, and after the 2nd time i just left it at a gold shield smog station for them to fix.
He diagnosed a weak vacuum in my egr valve, and it was due to clogged passages. I knew before hand that it could have been carbon clogging my egr passages, but some of components were so freaking hard to remove that i gave up hoping that replacing that little BPT hose would do the trick. Boy was i wrong and it costs me 200+ to fix.
Side story:Even though i passed the car didn;t run right. Jerked badly, and horrible has mileage. Took it back to them, they tried, but it helped little.
Eventually i got ticked off and replaced all the egr parts (bottom)
It seems they cut the top part of BPT-valve and jb welded it back together. ALso they replaced the BPT hose with some small *** generic hose that doesn't even make an L shape.
Think of this solution as a last resort. As i said before, the job is a PITA.
Modified by zer0c123 at 9:26 AM 4/23/2006
