Q451990 wrote:It can be done without dropping the transmission, but I can't find the old posts, even after searching for about 15 minutes. One member drilled a hole with hole saw in the floor pan, and then reinstalled a plug to close the hole. Another posted that he was able to drop everything down enough to access it from above between the firewall and engine. Maybe someone will have better luck finding the posts...
Heath
Here's Farfetched's drill-a-hole method, but it was a Y33, not a G50:
zerothread?id=116355
Squeefoo also managed it on a G50:
zerothread?id=164101
zerothread?id=73773
zerothread?id=89322
Modified by 96Qowner at 7:54 AM 3/19/2007
