90 Q45 surges when going up or down hill????
aliciaford
Car: 1994 Infiniti Q45
My Q runs great on the open road, going uphill it surges. If I accelerate and speed up, it goes away. I noticed the same thing yesterday only quite a bit milder going downhill. Any ideas???
Infinitiguy19
Car: 1993 Infiniti Q45 188580 Miles
1994 Infiniti Q45a 240000 Miles
Without previous service history I would have to say MAF sensor and connector just clean them Here: http://q45.org/maf.html
Then clean the throttle body: http://q45.org/tbclean.html
Then check your fuel injectors: http://q45.org/ohminjectors.html
And if not done so aready install a external transmission cooler: http://q45.org/trannycooler.html
And most importantlly of all install metal backed chain guides: zerothread?id=25201
Welcome to NICO by the way.
Modified by ppastos at 5:32 PM 8/6/2008
Modified by ppastos at 5:33 PM 8/6/2008
aliciaford
Thank you. I will have the hubby check those out. We were thinking it was starving for fuel. I had it serviced at the dealer and they indicated that the hoses needed to be replaced under the intake plenum. Might as well check it all... Again, thanks for the info.
Infinitiguy19
No problem you might want to check this out as well if you think its fuel starvation: zerothread/203341.
Do you hear a lot of buzzing comming from the back seat if so then it might be your fuel pump and it might be taking our the fuel pump controller Read this: zerothread?id=273138
maxnix
Car: 1995 Infiniti Q45
1995 Infiniti Q45t
2000 Infiniti Q45
If you have not performed any fuel system nor intake path maintenance, your symptoms are telling you your car is suffering from deferred maintenance.
But the timing chain guide problem takes precedence over all else!
Did you go to Infiniti of Kirkland or Infiniti of Fife?
aliciaford
Infiniti of Fife. Chain guides were done a few years ago. My poor car has had so much work done to it, Ive bought it 5 times over, I swear. But I still love her...Thanks for the help!
Infinitiguy19
So then you figured out the problem?
maxnix
1995 Infiniti Q45t
2000 Infiniti Q45
Say hello to Charlie the service manager.
I am not familiar with his technicians down there but he might have one Senior Tech (on who was trained on the G50 in 1989).
If you go to Portland, Eric at Infiniti of Beaverton is such a tech and their prices are a littles less and no sales tax.
