 need advice 95 Q45 162k, gas smell
ahmed_wasim
95 Q45
Toronto ON
9-2-2003
Guys,
I have 95Q with 162K on it. Last winter I noticed the gas smell when stopping at stop lights. Took it to Infiniti dealer they couln't replicate the problem. The smell vanished in summer.
Now since the winter has started (yes it has started in Canada) I can smell the gas again. If I open the hood I can smell gas from passenger side (after driving). The car runs smooth and has no problem otherwise.
I remember reading here about tightening somthing. Can you tell me what it is?
Regards,
Wasim.
elwesso
Super Moderator
Anderson and Angola IN
2-23-2003
 « Re: need advice 95 Q45 162k, gas smell (ahmed_wasim)
The fuel hoses on the back side of the plenum are probably at fault.
SHIFT_it yourself
1994 Q45t- 5 Speed
NICO Sponsor Directory | Infiniti Of Scottsdale, 1-888-216-5328
CrimsonQ
Purple People Eater
Kansas Chitty KS
4-20-2005
Sounds like the same problem I had (posted a thread with video of hose dripping sometime last year)
Was a 5-6 inch peice of hose running into firewall area under passenger side of plenum.
Only leaked on cold starts then after soking in heat it would stop.
1st gen NICO ecu - 93 tcu -- Williams FSTB -- 2.75" SS exhaust --
18" G35 wheels--255/45/18 -- President mirrors & trim -- SS Ultra
ahmed_wasim
95 Q45
Toronto ON
9-2-2003
 « Re: (CrimsonQ)
Hi,
Do you still have the video. Or is it still posted somewhere
Regards,
Wasim.
The care train has left the station.
LETS GO VANNING
ITS A PARTY IN THE USA
5-5-2003
I just tightened mine. Its the vertical rubber hose with two metal clamps, right below the IAC. You -can- reach the screws with a small screwdriver if you move the throttle cables. Its a lot easier though to buy an IAC gasket and remove the IAC for cleaning while youre back there.
1992 Cadillac Seville STS, 1998 Ford Mustang, 1991 Saab 900 Turbo convertible named Ducky
Quote, originally posted by MinisterofDOOM »
Get out of my gene pool. And take your ES350 with you.
BUY INFINITI PARTS - 1-888-216-5328 | NICO Porn Thread | http://www.q45.org | http://www.vh45de.com
http://justvan.ytmnd.com
A moment of wisdom from Butters: http://www.southparkstudios.com/clips/154323
ahmed_wasim
95 Q45
Toronto ON
9-2-2003
 « Re: (ahmed_wasim)
The link from last year
http://www.sdproducktions.biz/media/qfuelvid.mov
no longer works
CrimsonQ
Purple People Eater
Kansas Chitty KS
4-20-2005
ahh i need to pay my bill lol. Itll be back up tonight 8pm central.
I tightened mine as well but later replaced
ahmed_wasim
95 Q45
Toronto ON
9-2-2003
 « Re: (CrimsonQ)
Hi,
I tightened mine also. It was a small vertical one in the area shown in the picture. I was only able to tighten the bottom part of hose. There is no way to reach the upper part. I didn't try to tighten it too much, just 3-4 rotations, is that enough or should I tighten it more.
I drove the car after that, initially there was some smell but now it seems gone. I'll try again.
Regards,
Wasim.
Attachment: hose.jpg (98669 bytes, downloaded 2485 times)
goody90q45
Fly Me to the Moon
Online
90Q45
Orangevale CA
8-17-2005
 « Re: (ahmed_wasim)
That's the spot they were directing you to. I had two leakers back there when I first bought my Q and eventually was able to get to them both. I gave up at first but kept going back with different tools.
With the right tools you can get to the clamps you've given up on. Make sure to check for leaks with the engine cold as small leaks tend to slow down as the hoses heat and expand. As Jesda suggested, you may have to remove the IAC valve (adjacent to the right side of your circle) to get to all the clamps.
Hopefully you've reached and tightened the right clamp(s) and the fuel odor will go away once the residual evaporates. Good luck.
Mike "Goody" Goodwin
90 Q45 Base 249,000 miles . . It just keeps going, and going, and going.......
lino
1991 Q45a FED-SPEC
East Coast
8-15-2005
 « Re: (ahmed_wasim)
Are these the hoses you guys are referring to?
Can anyone tell if these look original or if they may have been replaced?
I checked mine and they are very tight. I get the fuel smeel in the morning when I start the car for the first time.
The cheapest place to buy New Genuine OEM Nissan, Infiniti and Datsun parts.
Try to beat these prices:
http://stores.shop.ebay.com/em...mrsZ1
96Qowner
Supporting Member
1996 Q45
Fargo ND
9-7-2004
 « Re: (lino)
Those aren't the ones. The usual suspect is a fuel hose buried deep under the middle of the plenum. It connects to the fuel pressure regulator and leads to the hard line to the fuel filter. Kinda under that yellow rectangle in the previous pics.
1996 Q45 -217,000 miles
1990 Accord - 398,000
1966 Thunderbird Q code - 87,000
lino
1991 Q45a FED-SPEC
East Coast
8-15-2005
 « Re: (96Qowner)
Thanks I'll try to locate it tomorrow morning.
GeesQ
1994 Q45
Los Angeles CA
8-3-2006
 « Re: (lino)
I had the same problem with my 94 Q and this morning I tightened those hoses and it seemed to have done the trick. The screws were amazingly loose where I was able to turn one about 4 times and the second one about 3.
lino
1991 Q45a FED-SPEC
East Coast
8-15-2005
 « Re: (GeesQ)
Anyone have any pics?
Q45tech
Q45 Guru
1990 Q45 325,000 miles 19.9 years ownership
Marietta , Georgia
4-30-2002
 « Re: (lino)
Modern fuels eat these hoses from the inside and thus their I.D. increases.
Tightening once is just a temporary fix.
Just part of the PERIODIC [every] 80-120k under plenum hose replacement.
Copyright 2009. Nipuspan International Corporation. All rights reserved. This material may not be broadcast, rewritten or redistributed.
http://www.t3atlanta.com/
» Return to Q45 Forum / Cima Forum
