90 q45 engine shuts off rolling to a stop low rpm please help!!!
jettsetter4life22
Car: 1990 infiniti q45
yeh so this started happening about a week ago and its getting worse. basically whats happening if i dont let the engine warm up for about ten min once i put it in drive ill make it ten feet come to a stop and the engine will just die! my message center sais battery voltge low. the engine will usually start back up right away sometimes it kinda hesitates on starting for a few seconds although the engine is cranking normally. the wierd thing is it almost only does it when im coming to a stop. I dont know mabye an ect sensor or something i have no clue where to start with this obd1 crap! i checked batt voltage at 12.8v charging at 14.2. please help any help is appreciated.
bryan
qship96
Car: 1996 Infiniti Q45
Thats the beauty of later cars with OBD2.....intermittant faults are easier to track down.When my 96Q started with symptoms like yours, I got a code for MAF....replaced MAF and problem went away,$450 part if purchased from Infiniti of Scottdsale,closer to $650-900 from your local Infiniti dealer.
You could buy a used one off e bay, but probobly a short term fix at best as it will be just as old and tired as the one that just failed on your car.After 12+ years of heat cycles and road vibration, the solder joints just give up and fail-intermittantly at first,then finally for good.
maxnix
Car: 1995 Infiniti Q45
1995 Infiniti Q45t
2000 Infiniti Q45
jettsetter4life22 wrote:if i dont let the engine warm up for about ten min
So what does the concept operating temperature mean to you?
Any maintenance history? Specifically the fuel and intake systems?
Lecar Prodigy
Car: 95 triple black q
i dont know if u checked but definently check the air flow sensor...there is a plug that goes into it and sometimes it gets a short..i had problems with it and it stalled and hesitated alot..the funny part is i saw someone wit a 93 q and i never asked him why his was cuttin off like that but i found out
test: start the car and check the air flow socket if u give it a jiggle and if u stall u found ya problem....i use to have to give it a jiggle and it would work temporarly but after doin that with people in the car after a while that got old...and embarrasing .
Q45tech
All bets are off on an 19 year old car if you don't let it warm up to operating temperature before attempting to drive away.
A Consult test of IAC will probably show dirt, slime, and oily carbon in IAC and around TB plate and housing.
Infinitiguy19
Car: 1993 Infiniti Q45 188580 Miles
1994 Infiniti Q45a 240000 Miles
Do you mean what percentage the IAC is running at?
And if so it could also mean that is was turned up to rectify a symptom, IE: High Idle, And was never turned down.
Q45tech
The is no ZERO standard for IAC during warm up, the 10-15% IAC duty cycle is specific for a 174F coolant.
The usual problem is some incompetent owner or mechanic fiddling with the DO NOT TOUCH adjustments on the throttle body and hot wax idle warm up control.
Infinitiguy19
Yea that damn throttle is what I have to replace, Lucky me that I have 2 of those TB waiting.
Q451990
Q45tech wrote:All bets are off on an 19 year old car if you don't let it warm up to operating temperature before attempting to drive away.
Although it's ideal to let the car warm up to normal operating temperature - the car should function and drive... not that I'm saying Q45Tech is saying it shouldn't... but don't let the car's age discourage you from finding and fixing the problem.
I think everyone here is on the right track with the MAF.
Heath
Haitian_King
Car: 1992 Black Infiniti Q45 /w TCS
1995 Black Infiniti Q45
I want to say MAF. Check it out.
jettsetter4life22
ok well this morning it stalled again after i let the engine warm up but its only at idle when im stopped or almost stopped. i perfromed the wiggle test on the maf while the engine was running and it didnt stall tried a procussion test on it as well nothing. how to i test this maf and check for any codes?? my all data is not giving me anything for this damn car.?? are you saying there could be a problem with the iac or tps?? thanks for the input thus so far
bryan
maxnix
1995 Infiniti Q45t
2000 Infiniti Q45
We call "All Data" Some Data.
Do you have the FSM?
http://www.nicoclub.com/FSM/Q45/
When did you last clean your IAC valve? EGR? TB? Plenum? Replace fuel pump? Fuel filter? Measure fuel pressure?
jettsetter4life22
REALLY THE ONLY THING IVE DONE IS PLUGS ON THIS MOTOR NGK PLATNUM.
maxnix
1995 Infiniti Q45t
2000 Infiniti Q45
Presuming the PFRG were used, then all else remains to be done.
IAC, EGR and TB are not that difficult with the gaskets on hand, and a torque wrench. The plenum is a whole 'nother story, and a good time to do VC gaskets. Wonder if one has a leak? Any oil on any of the plug exteriors?
jettsetter4life22
WELL I FINALLY GOT A DAY OFF DAMIT SO TODAY IM PUTTING IN MY NEW TRANSMISSION(LOST 3-4 GEARS WOUDNT SHIFT) AND THEN WE CAN DO FURTHER TESTING ON THE ENGINE WITH A NEW transmission. QUESTION COULD MY JUNK TRANSMISSION BE CAUSING ME ENGINE TO ACT UP? CAUSE I DID NOTICE WHEN THE ENGINE WAS ABOUT TO DIE I WOULD PUT IT IN NUETRAL AND THE ENGINE WOULD RETURN TO NORMAL IDLE ABOUT 850RPM. THANKS FOR THE HELP WISH ME LUCK!
maxnix
1995 Infiniti Q45t
2000 Infiniti Q45
YOU DON'T NEED TO SHOUT!
Please disengage the Caps Lock key.
So, how about your fuel pump? Have you measured the pressure?
Installing a Nissan remanufactured transmission?
Modified by maxnix at 6:35 PM 11/7/2008
Haitian_King
Could it just be that the AT is low on fluid?
jettsetter4life22
WELL I PUT THE USED TRANSMISSION IN(FROM JAPAN CLAIMED TO ONLY HAVE 40K ON IT) AND THE STALLING PROBLEM WENT AWAY SO I GUESS IF YOU ONLY HAVE 1/2 GEARS YOUR Q45 WILL STALL AT IDLE?? ANYWAYS EVEYTHING IS GREAT EXCEPT I HAVE A NEW PROBLEM. IF I HIT IT WOT THE transmission WILL UPSHIFT SMOOTH ALL THE WAY UP TO 4TH THE PROBLEM IS AFTER I SHIFT FROM 2-3 AND LET OFF THE GAS IT WILL DOWNSHIFT BACK INTO 2 AND THE CAR WILL NOTICABLY FEEL LIKE ITS DRAGGING AND SLOW DOWN UNTIL I EVEN LIGHTLY PRESS THE GAS AGAIN AND IT WILL GO BACK INTO 3RD AND GO SMOOTH UP UNTIL 4TH AND ILL HAVE THE SAME PROBLEM IN 3/4 AS IN 2/3. NOW THE TRANSMIOSSION WAS SLIGHTLY DIFFERENT THAN MINE ALTHOUGH THE CONNECTIONS ALL PLUGED RIGHT IN NO PROBLEMS. I ASUME ITS A NEWER MODEL TRANSMISSION ABOVE 90 OR IT WOULD BE THE SAME AS MINE MY MANF DATE IS 11/89. SO IS IT POSSIBLE I NEED THE NEWER MODEL (93+) TCU TO GET THE SHIFT TIMING RIGHT? ANY HELP IS APPRECIATED THANKS ALL YOU GUYS FOR YOUR HELP. (SORRY CAPS LOCK KEY IS BROKEN)
BRYAN
Infinitiguy19
Well it could be a newer 1993+ transmission or maybe the throttle position sensor is off a little.
Can you confirm what year its from?
89-92 are all the same some 93*-96 are the same as well
*Some early 1993's have the 1992 transmission.
Did you run AT-CHECK?
Was the transmission installed correctly because a transmission isn't some thing that you decide in the morning "Hey my car is running/shifting crappy I think will change out the transmission."
Sorry but you have to plan it out just as with everything or almost everything in life because you need to get an *OEM re-manufactured Then you take it to a professional who know these car inside an out and installs it right.
*If you want it to last longer than a used
Any ways good luck.
maxnix
1995 Infiniti Q45t
2000 Infiniti Q45
No, the 1990-1993 all had the shorter 1st and 2nd gears.
Infinitiguy19
Man if there was a way to see the numbers on on my transmission with out removing it I would prove your wrong I bet.
I mean I don't see a ton of difference, despite the fact that I need to do some maintenance but I am 99.999% sure I have a 1994 transmission because IOS has said my car calls for the later transmission.
maxnix
1995 Infiniti Q45t
2000 Infiniti Q45
You must read the FSM, Grasshopper.
From http://www.nicoclub.com/articles.php?id=170120
Transmissions:90-93RE4R03A 51x65 transmission4 speed autoGear Ratio1st 2.784:12nd 1.544:13rd 1.000:14th 0.694:1
94-96RE4R03A 51x79 transmission4 speed autoGear Ratio1st 2.569:12nd 1.479:13rd 1.000:14th 0.694:1
Infinitiguy19
What info do you need to prove that I have a 1994 transmission?
maxnix
1995 Infiniti Q45t
2000 Infiniti Q45
You need to get the number off the top of the bell housing.
Personally, it macht nichts to me. You may not have have the original transmission.
qship96
ppastos wrote:What info do you need to prove that I have a 1994 transmission?
You may have a 1994 transmission in your car if the original transmission was replaced while owned by one of the previous owners of your car, but I seriously, seriously doubt our car left the factory with a 1994 transmission installed in it......thats the problem with buying old cars that have had multiple previous owners, you never know what each one did to the car while they had it.
Infinitiguy19
Yea I have not receipts form the previous owner not GloucesterQ45, But the woman who owned the car in Florida Her name which I will keep to my self of course.
And the service history explains nothing about the transmission besides the fluid exchanges.
I want to see though If I can some how get the code off the transmission with a little camera or something, But that's making a mountain out of a mole hill or going waaaaaaaaaay to far to prove a point.
qship96
Who cares what code is on the transmission???/ Still doesnt prove the transmission currently in the car is THE ORIGINAL one it had when it left the factory!!!!
Infinitiguy19
That's true but wouldn't giving your VIN to Joe or any Infiniti dealer's parts dept. be able to tell you what transmission it calls for or came with?
qship96
calls for-yes came with- not so sure! I wonder if all the current available nissan remans are the later model transmission?
Infinitiguy19
But hopefully there still is 90-93 trannys.
