Ok... so the brake light bulbs are new, but don't work - the tail lights work - but the only brake lights that work when the brake pedal is pressed are two bulbs in the CHMSL (center high mount stop light) in the back window?slshearer wrote:No
But the warning light is now on!
The inside brake light is still working
I haven't seen you mention checking/cleaning the female sockets in the brake lamp modules. If your bulb sockets were showing signs of melting chances are the female sockets are doing the same. I've seen them melt through and still operate but with the warning message.slshearer wrote:Hi
I have replaced all the bulbs including the turnsignals, reverse tailight/brake lights, I did not know about the LL (long life) ones but I will get them ASAP, It is the 2 brakelights (4 Bulbs) where the turnsignal are located that do not work, I will investigate the sensor next.
I know it sounds like a bunch of phooey but the Sylvania LL (1057L) really do make a difference and will clear up the error message it all else is well (I speak from experience). Also, aren't the brake bulbs on a fuse separate from the tail lamp bulbs? Have you checked the fuses? Good luck finding the gremlins.
BTW- I have a purple sensor for sale. Email me if you're interested.
I have never heard of a failure on the Y33 or F50... maybe they beefed the sockets up a bit. It's still a good idea to only use good quality bulbs though... no Dollar General bulbs in the QRAP wrote:so is the problem outlined above also one us 2000 owners have to concern ourselves with?
I assume there's a different one for the "T" spoilers - I think it just uses one bulb instead of two.Paul Wall wrote:Also to add:
Purple box=1990-1993 Q45 tail/stop lamp sensor.
Black box= 1994-1996 Q45 tail/stop lamp sensor.
I found the above out the hard way when I was stupid enough to sell the possible working part for stupid cheap, and now I need it.
Modified by Paul Wall at 12:06 AM 9/4/2009
I am unsure how many bulbs the T spoiler uses but I think I agree with you on one bulb.Q451990 wrote:I assume there's a different one for the "T" spoilers - I think it just uses one bulb instead of two. Heath
Someone want the "JDM Tyte stuff" too I see.Q451990 wrote:I would like to figure out the difference between the sensors to see if they can be "tuned" to a lower current draw if I switch to LED bulbs - so that I can still have the functionality of the bulb out warning.
Heath
That's correct. I believe the 94-96 used one bulb for the tail/stop section instead of two...mattd1979 wrote:If you were to swap in the tail lights from a 94-96 into a 90-93, you would need to also swap the tail light module from the same vehicle that you got the tail lights from right?
