89 s13 w/ s13 sr20 redtop wont idle!!
skyline084
Didn't you said it idles fine, but NOT when it's warm?
The fuel pump will def help and be noticed at higher rpms.. cause you're running a turbo charged motor... so it needs more fuel..
More air (turbo) needs more fuel.
240bryce
Car: 89 240sx w/sr20det redtop
didnt fix it guys... :frown: i installed it today & then took it out for a spin & its still doing the same thing!!.. except now if feels like its only bogging during boost and WOT revv. The fuel pump actually made a noticable difference though.
Oh and i dont think iv mentioned this yet, but when the car is idling.. it starts out at like 800rpms then rises to like 2000.. then drops back down to 800 & does the same thing continiously till i shut the car off. i cant figure this thing out
Lobo240sx
Car: 1991 Nissan 240sx Coupe SR2.35DET Redtop Build
Possible Vacuum leak on intake side near IACV. Hate to say it, could be a hose coming off the Intake Collector that has a small leak. As much as you have gone through it, i'd make sure your throttle body is completely closed while idling too.
skyline084
fix this thing yet?
240bryce
Yeah man i took it to Topspeed tuning in alpharetta, ga &they said it was all 4 coilpacks, intake manifold gasket, throttle body gasket and the vac lines were messed up... :facepalm:
i thought i checked those things!!
But anyway shes finally running :bigthumb:
