Do you mind sharing a little info on your setup? I.e. What did you do for engine/trans. Mounts? Did you run into any problems with the driveshaft (probably custom)? What trans are you using? Who made the oil pan? I'm just trying to gather as much info. as possible b/c my dad is a ford guy and has an extra engine. I'm done getting there in a straight line and its time to start getting there sideways with a stock 5.0. Thanksmaik21 wrote:my 240sx s13 has a 5.0 carb engine. it has a custom oil pan and the oil pump is in front .. u need maybe to mod the stabilizer bar or maybe place the engine too back. and do a custom headers.. i didnt do that yet, because i need to import some tubes.
http://www.youtube.com/watch?v=mqbNffyIpbE
sorry at the moment...i only have a video in youtube to show my car with the engine sound of a v8.. my laptop now is virus and i cant get the little pictures of that. i can tell u that the driveshatf is a custom driveshaft.. it comes from a ford grand marquis and was welded with the end of the driveshaft that bolts with the diff... my transmission is a aod and was rebuild 1 a few months ago... i didnt cut any part of the chassis to done the swap... but i can tell u that is a "must to" because u need to place the engine near the firewall to make room for electric fans and other stuffs!!! i have my electric fans in front of the radiator.... not between radiator and engine!! ... and the oil pan? yea.. its custom made...any one can make one with the apropiate tools.. u need to cut and paste and make it with the some liters of oil to avoid problems. my engine has the oil pump in front !! the only problem i had was the front stabilizer bar.. it is custom to... and its a pain in the *** .Agent 47 wrote:
