89 240sx smoking
djtrickstick
my car smokes real bad when you gas it, and still smokes during idle but very little hard to notice unless you look close. friend told me its most likely valve seals cause it only smokes when you gas it. should i just get a rebuilt head off ebay and slap it on see if it stops or somethign else i should do? also it runs good just smokes.
OutToWinPAHC
Car: 2015 Chevy Silverado
Nissan Skyline R33 GTS-t
Nissan Skyline R32 GTR
Nissan RB20 E46 RHD
2015 Harley Vrod Muscle
1990 Nissan Patrol
Is the smoke blue?
If so, no need to replace the head, you can do the valve seals and reshim the lifters without removing the head.
djtrickstick
no its completely white i dont see any bluish in it
OutToWinPAHC
Nissan RB20 E46 RHD
1990 Nissan Patrol
Thats not vavleseals....... Thats water burning.
Common causes -Warped headHeadgasket failureCracked block, or head
Let me guess, your overheated recently?
djtrickstick
no see thats what tripped me it doesnt overheat at all and no loss of coolant or water.
OutToWinPAHC
Nissan RB20 E46 RHD
1990 Nissan Patrol
drain your oil, see if its milky or green
adrianfromthecastle
Car: 1992 Nissan 240sx
it could be just running really lean...
does your idle jump around sometimes? any backfires?
djtrickstick
idle bounces sometimes not alot just a little then it goes away, how do i adjust my fuel intake?
djtrickstick
i just changed oil cause it was a little brownish and since i just bought the car i figured i dont know when it was last changed so it cant hurt.
s13_chris
Car: 90 240sx Hatch
You bought a smoking 240sx that you don't know how long its been since the oils been changed. Nice.
OutToWinPAHC
Nissan RB20 E46 RHD
1990 Nissan Patrol
Since you just bought the car you also dont know if it was overheated......
Check the compression
IanS
Car: 2002 Subaru WRX, 2010 Subaru Forester XT, 2004 Infiniti G35 Coupe.
Valve seals wont usually smoke at under throttle. They ussually smoke the most during engine braking.
On throttle, you may have a combination of bad rings, and a bad PCV. If you get smoke under load, its usually from blowby.
djtrickstick
ok so imma do a compression and leak down test this weekend, what are some clues that my piston rings are bad? and imma replace my valve seals as well this weekend
