evildky »
https://forums.nicoclub.com/evildky-u13100.html
Sat Aug 22, 2009 6:14 am
the timing you adjust be rotatign the distributor, same as any other distributor fired car, th eidle, can be tricky, there is an adjustment ont he throttle body but idle air should be handled by the aicv, I don't think it was adjustable on the 83 but it's been a while since I've delt wiht a stock one
a rough idle coudl also be a misfire by way of a fouled plug, bad plug wire, cracked distributor cap, bad injector connector, bad injector, bad lifter etc
