'83 280ZX TURBO
A forum for owners of S30 and S130 Datsun Z's... 240Z, 260Z, 280Z and 280ZX!
Perrenial Badass
Car: 1973 240Z, 1986 300ZX, 1987 300ZX, 1984 Corvette
Silviagirl79 wrote:Ohh and makes a thudd when i left off the gas.....is this is the diff mount loose?
When moving? It could be. If you can get it up on a lift, I would check all the rubber bushings to make sure that they are all still in good shape.
evildky
Car: 71 Datsun 240ZT
87 Nissan 300ZX N/A-T
06 Nissan 350Z GT
Toyota Tundra TRD RW
sounds more like a trans mount issue, when the pinion mount goes the pinion lits, often hiting the e brake linkage and makign a ratteling sound at the U joint rubs
Silviagirl79
Car: I love Silvias, Skylines, Soul Calibur II, and GT3
Thanks!
Want to do a compression test on this engine, bought a compression kit. What do you unplug ignition and fuel-wise? The fuel pump relay, and unplug ignition coil wire?
evildky
06 Nissan 350Z GT
yup, actually is you unplug the distributor the injectors nor the coil will fore which would e easier, and be sure you wire the tb wide open when you test
Silviagirl79
evildky wrote:yup, actually is you unplug the distributor the injectors nor the coil will fore which would e easier, and be sure you wire the tb wide open when you test
when you say unplug the distributor do you mean all the spark plug wires, or the center ignition wire?
yes, as far as the tb i will have my foot pressed on the accelerator pedal at WOT
evildky
06 Nissan 350Z GT
as in disconnect the 4 prong round connector that comes out the bottom of the distributor, and yes the foot can work, just more consistant if you tie it open
Silviagirl79
Well I finally did a dry and wet compression test on this car. Had noticed some oil on my spark plugs and suspected the piston rings.
Here are the numbers.
Cylinder 1: 120 psi / Wet 160 psiCylinder 2: 120 psi / Wet 170 psiCylinder 3: 130 psi / Wet 150 psiCylinder 4: 120 psi / Wet 145 psiCylinder 5: 130 psi / Wet 163 psiCylinder 6: 135 psi / Wet 173 psi
Not bad for a 26 yr old Turbo engine. The minimum should be 100 psi, Normal is 140 psi.
Looks like I have a Piston Ring problem though, right?
I'm going to just replace the Piston rings, Head Gasket, and Valve Guide Seals/Stems all at once.
Since I want to put a T3/T04E .50 Trim, .63 a/r turbo on there, Intercooler, 3inch exhaust and turn up the boost.
Modified by Silviagirl79 at 12:51 AM 10/14/2009
Modified by Silviagirl79 at 12:52 AM 10/14/2009
evildky
06 Nissan 350Z GT
your readings are low and show worn rings but not so bad it shouldn't run, but if you want to put a fatty turbo on it a fresh bottom end would be a good idea, maybe raise the CR a bit while you're at it
Return to “Datsun Z Forum”
