6boost RB exhaust manifold Group buy $730!
eh?
Quote » i still got no manifold....
if eh? gets his b4 me i will be
where is everyone elses pics...like 3 ppl have posted pics...i wanna see the rb26 car
Modified by toadx8u at 8:40 PM 12/4/2008[/quote] Email Kyle about the tracking info. In the last email I got from him he said he would send on the tracking info to each person (he called it con notes -whatever that means)
eh?
sci2000tech wrote:I told kyle to make mine for a 50mm wastegate, and the ID of the piping matched up to the flange perfectly. The wastegate tube is a little bit larger diameter than the rest of the manifold.
Here is another crappy cell pic with the wastegate mounted.
Can you take a pic a lil bit further out? I'd like to see where the w/g is placed against the master cylinder.
MATTs14
Car: Red 1995 Nissan 240sx
Well my dilemma is that i told him i would be running a 38 now and i thought i told him that i would eventually upgrade to a 44 but the message didnt go through so ive got a 38mm outlet. The question is can i stll run a v44 tial on the 38mm outlet and be okay?
eh?
MATTs14 wrote:Well my dilemma is that i told him i would be running a 38 now and i thought i told him that i would eventually upgrade to a 44 but the message didnt go through so ive got a 38mm outlet. The question is can i stll run a v44 tial on the 38mm outlet and be okay?
Either cut and reweld or buy this
http://www.atpturbo.com/Mercha...e=FLS
MATTs14
But will it still hold boost fine. Thats what im asking
eh?
How much power are you looking at?
MATTs14
400whp with the 20. Im gonna be looking at near 6 with the 25 im building. I was just wondering if i could weld a flange on there for the 44mm and it still work and hold boost fine
eh?
MATTs14 wrote:400whp with the 20. Im gonna be looking at near 6 with the 25 im building. I was just wondering if i could weld a flange on there for the 44mm and it still work and hold boost fine
I think you'll be okay with the 38mm and 400whp. But I'd be looking at dual 38's for 600rwhp.. I don't think pipe size is the only factor, I think the w/g valve lift will also play a role too.
Modified by eh? at 12:42 AM 12/6/2008
DriftingisLame
Car: '91 240sx coupe, rb20det
MATTs14 wrote:So we all got the same size pipe for the outlet??? And i will be glad to share any and all info i have with you. Im glad to see that someone else is going this route. Im worried now that my wastegate outlet is too small. I assumed they were all the same size. Does yours appear to be the same size pipe as the rest of the manifold??? ANd mine is forward facing btw
Matt I just measured the diameter of my wastegate tube on the manifold. It measured 44mm ID.
sci2000tech
Car: '92 Nissan 240SX S13.5 RB20DET 'Vert
Well, I wasn't able to grab my camera today....but here's a pic showing the wastegate in relation to the brake MC. There is a surprising amount of space even with a WG this big.
MATTs14
Hey DriftingisLame, wanna trade?? haha. BUt i think i will be good. Im gonna start with the 38mm on my rb20 and will upgrade to the 44 when i get my 25 done. This sound good to you guys?? Will i be able to do this with the 38mm tube?
240z4u
Car: '95 Nissan 240SX
You won't have any boost control problems I am sure.
Evan
MATTs14
Ok thanks man. I just needed some reassurance lol. I tend to worry about the little stuff. Lets see some other peoples setups on here
74260zt
Car: rb26powered early 74 260z car
So who bought one of these manifolds for a rb26? I'd like to see that one also...
MATTs14 what turbo is that you are using?
Modified by 74260zt at 11:52 PM 12/5/2008
eh?
I'm pretty sure the owner would like to remain anonymous (seriously)
MATTs14
IM running a holset hx35 for now
DriftingisLame
Matt, can you do me a favor? On your wastegate, can you measure the inside diameter of the flange that bolts to the manifold on your 38mm wastegate? I'm not sure what part of this is supposed to be 38mm, but the ID of that flange on my wastegate is like 32mm, and the outlet of the wastegate I believe is 38mm.
I'm kind of confused, and worried I got ripped off... Also, is yours a tial? I have a Turbonetics deltagate, it was advertised as a 38mm.
Thanks
eh?
DriftingisLame wrote:Matt, can you do me a favor? On your wastegate, can you measure the inside diameter of the flange that bolts to the manifold on your 38mm wastegate? I'm not sure what part of this is supposed to be 38mm, but the ID of that flange on my wastegate is like 32mm, and the outlet of the wastegate I believe is 38mm.
Thanks
The 38mm refers to the valve diameter, not the inlet or outlets
DriftingisLame
Hmm okay, that will be a little more difficult to measure lol. Still seems like its maybe a 35 and not a 38. Im gonna be really pissed if thats the case
MATTs14
I dont have my tial yet lol. But like he says it is the valve diameter. IF it is a 35 just use it for now and cut the flange off and upgrade later. This is what i'll do or get the adapter as mentioned above
eh?
Just got my Synapse 50mm w/g. This things has almost 50% more lift than my hks 40mm...
eh?
Cometic exhaust gasket
MATTs14
Can we still get those exhaust gaskets?? It slipped my mind and i havent paid for it yet. Also do you think i could get that 50 mm synapse to mount on my 38mm wastegate tube
krayton
my forward mount hits one of my heads oil drain tubes. shouldnt be a problem. just giving a heads up
Bluefire
sci2000tech wrote:Well, I wasn't able to grab my camera today....but here's a pic showing the wastegate in relation to the brake MC. There is a surprising amount of space even with a WG this big.
is this a forward facing one or a normal one?
DriftingisLame
Bluefire wrote:is this a forward facing one or a normal one?
Thats a forward facing I believe.
Guys I apologize for always having stupid bad cell phone pictures, thats just all I have access too right now.
Still need to clock the housings, this is just a test mount.
eh?
MATTs14 wrote:Can we still get those exhaust gaskets?? It slipped my mind and i havent paid for it yet. Also do you think i could get that 50 mm synapse to mount on my 38mm wastegate tube
I'm not 100% sure but it will fit the 44mm tial flange. That adapter I posted above should work.
MATTs14
Nevermind im gonna go with the synapse 40mm. Anybody have any opinions on this wastegate??? And is that your hx35 driftingislame??? That looks nothing like mine. Can you post up some pics of the vband???
74260zt
eh? wrote:Just got my Synapse 50mm w/g. This things has almost 50% more lift than my hks 40mm...
Do you mind revealing where/how much for the 50mm Synapse... those are bada$$.PM me if necessary. Thanks - j.
eh?
Got it on ebay for $328 shipped but getting $94 cash back from MS live.
