MATTs14 wrote:and did everyone get the same size outlet for the wastegate? i told him 38mm tial but will eventually want the v44 tial. Can i stlll do this?
Matt,
You and I are running the same turbos and same manifold, I'm interested in any pictures, or info about your setup you can provide me with. Do you have a forward mounted manifold or center?
I have the same issue with the 44mm tube and the 38mm gate. I e-mailed kyle about it and this was his response...
"To answer your question, a 38mm gate is very small on pne of my manifolds. If you are going to run a decent turbo, IE a GT35 or similar, then a 38 will be too small. However if you are running a relatively small turbo, a 38 may be fine. I will put it to you this way, having a bigger (44mm) gate outlet with a smaller flange welded to it, regardless of turbulence, will have better boost control and flow than a small pipe and flange. The bigger opening in the manifold will catch more gas. So I would say if you can afford it, a 44mm gate would be nice, but if not, what you have is better than having had a 38mm pipe on the collector regardless of gate:-)"
I've spent my budget on this new setup. I'll be running the 38mm gate either untill I can afford to upgrade to the 44mm, or if I have massive boost control issues.
I think we should be okay for now, but it isnt the ideal wastegate setup.
