WDRacing wrote:A little off topic, but does anyone know who has the fastest KADET in the states. If Duy's is the fastest, then I'll use his car as the competition. I think it would be nice to say i have the fastest ka powered 240 in the states. Street legal with a functional interior by the way.
WD
WDRacing wrote:Consider it STOLEN....
PS, for you moderators out there. How do I get PM capable? Is that a paying member only benefit?
TrueSlide wrote:I cannot remember stock specs on pistons, but I do know you cannot really overbore it, If you take one apart you will see whyYou can maybe get a .5 but even that could be overboard(HAhaH, I kill myself, jkin)
http://www.sdsefi.com/features/240sx.htm If you scroll down you can see why the block really can not be bored, very thin walls between each cylinder.
i believe he wants to retain as much of the torque curve as possible while extending the rpm's will allow him to take full advantage of whatever turbo he decides on. not having enough revs left to spin the turbo to the point of losing abdiatic efficiency would pretty much suck.matt0941 wrote:Why would you build your bottom end in order to increase your revs on a stroke motor like the KA?
jmac wrote:i believe he wants to retain as much of the torque curve as possible while extending the rpm's will allow him to take full advantage of whatever turbo he decides on. not having enough revs left to spin the turbo to the point of losing abdiatic efficiency would pretty much suck.
