Black B15 »
https://forums.nicoclub.com/black-b15-u203162.html
Fri Apr 26, 2013 3:30 pm
What i'mstricken said. I basically keep a bottle of the CRC Mass Airflow cleaner handy. We touched on this in another thread, but especially if you are using an aftermarket filter that you oil (Like a K&N panel filter) there is a chance that it was over oiled and that oil will flow past the MAF sensor causing it to somewhat gunk up. This can cause the exact symptoms you are mentioning. It should be pointed out that the MAF can also just get dirty from everyday driving, but over oiling a filter is a big problem for the mass airflow sensor.
Again, like stricken said...you can literally hose that sensor with the MAF cleaner. When you take out the sensor, you will realize it is directional with the air flow from the intake. When you look in those little openings that stricken pointed out, you can see the little metal wires in there. Just hose those off, DO NOT SHAKE DRY....it will evaporate rather quickly. I usually let mine dry for about 5 minutes just to make sure there is no fluid left in there.
I did this to my Sentra probably 30 or 40 times over the course of 150,000 miles. I never had a problem once with using this product.
