Idle Relearn
This seems to be a pretty common thing if you swap tbs or clean your tb. Here is how you do it.
-Warm up engine.-Turn ignition switch ?OFF? and wait at least 10 seconds.-Confirm that accelerator pedal is fully released, turn ignition switch ?ON? and wait 3 seconds.-Repeat the following procedure quickly five times within 5 seconds.a. Fully depress the accelerator pedal.b. Fully release the accelerator pedal.-Wait 7 seconds, fully depress the accelerator pedal and keep it for approx. 20 seconds until the MIL stopsblinking and turned ON.-Fully release the accelerator pedal within 3 seconds after the MIL goes ON.-Start engine and let it idle.-Wait 20 seconds.
