ScottJackson »
https://forums.nicoclub.com/scottjackson-u14976.html
Tue May 27, 2008 11:13 am
Oh, but yes it is available in pushrod engines. Check to new Viper V10 for proof. I understand that for an ultra high rpm engine pushrods can be detrimental. But at what cost? For a street engine, I bet a person would be completely unable to tell the difference between an equivalent (same compression, rpm range, idle quality) pushrod engine of the same displacement as a DOHC engine. If you want the best, don't even use valve springs. They are an old-fashioned cheap way of closing valves. We all NEED a F1 engine in our street cruiser with a 20,000rpm redline that will bog and die if we try to leave a stop light at less than 6,000rpm As far as rotational mass, I bet 4 cams take more energy to spin than a single cam actuating pushrods. The rocker arms are offset by the VH's followers. I'm not saying the VH is a bad engine. It's a fine engine, but if you want a lot of power without having to spend a load of money and a big headache, a good pushrod engine is tough to beat, and it fits in a small space easily. Like I say, both are fine, but for a typical application of 8000rpm and less, good luck being able to tell the difference in seat-of-the-pants feel assuming both are equivalently built and of same displacement. The beauty of the pushrod design is you can build very large displacement cheaply while being able to swap it in the place of a much smaller displacement DOHC engine... and it's cheap, easy, effective. Comparing a 7.5:1 smogger 350 chevy from 1975 to the VH isn't fair because it's not the basic design of 2 valves and pushrods making it such a dog. It's the cam, cam timing, intake, compression, combustion chamber design, ignition timing, and exhaust which is holding it back.
