98KA24DET wrote:I would not run a turbo ka WITHOUT an intercooler.. Thats asking for detonation unless you have a SUPER efficient turbo..
Not so...
People always think an intercooler is an ABSOLUTE necessity of a turbo system...
But run the #s...
At 85-degrees ambient, with a turbo boosting 8psi in a 70% efficiency range...the outlet temps will theoretically be 187-degrees F. So w/o an intercooler, the engine sees 187 F...
Then, with the same ambient temps and same efficiency, boosting 25psi BUT using an intercooler (with a generous 75% efficiency rating)...the outlet temps would be 327 F, and the intercooler would cool it by 181 F, leaving the motor to see 145-degrees F...but at a MUCH higher overall cylinder pressure due to the increased boost (3X as much).
And none of us would have a problem running the 25psi (with a built motor, and the right amount of fuel and tuning, etc...) - But you say an extra 40-degrees F is asking for it. I say the extra cylinder pressure from the 17psi of boost is more likely to detonate, but it doesn't.
So why does an extra 40 F add so much danger...it doesn't.
Sure, you'd find ~7% more power with the same intercooler at the 8psi setup...but the detonation level isn't reduced as much as we'd all like to think it is.
EDIT: Oh yeah - Here's the basis for the numbers above:
http://www.gnttype.org/techare....html
Just some food for thought...
Later - Brian
