MarkEmark »
https://forums.nicoclub.com/markemark-u744.html
Mon Jul 14, 2003 3:35 pm
I hate to admit it, but almost $2000 later, and I'm not nearly satsified as I should be. My brothers little 1.8 liter Audi is making my car look silly. I have no idea what it is, but my car is just not making the power. It's at 6 psi right now. When I was running it w/o a cat and just the downpipe at 6 psi by myself, the thing felt decently fast, a good part of that being attributed to the burly noise/sound of the turbo spooling. I recently had a pipe made to replace the stock cat (2.5") that went to a high-flow catco catalytic converter (2.5") that goes to the rest of my straight bend Tanabe exhaust (2.5"). 2.5" is by no means small; and the cat is high-flow and not till pretty far down the downpipe. The car is extremely quiet, and psychologically I think that's why it feels a bit slower...
However, driving with my brother today, 2nd 3rd and 4th gear, when I would floor it, it would see a full 6 psi from 3k-4k RPM, and then immediately at 4200 RPM, like clock work, it would drop down to 4 psi all the way up to 6000 RPM. It felt at 4k rpm like the engine was ready to do something...and then it just poops out and makes no more hp (actually less) up in the RPM'S where it should be making a ton.
I've learned many things out of this installation--one is to make sure I know EXACTLY what pieces came from what and how old they are. All that I know about the turbo is that it's an AiResearch T3, internally wastegated, and that its exhaust side has an A/R of .48. Now .48 is pretty low...but theres no reason in hell the turbocharger should be crapping out past 4k rpm.
I don't think there's a boost leak anywhere; I'd hear it. The only way to check is to measure the boost EXACTLY at the TB, and not off of the BOV (which is right at the beginning of the compressor pipes going to the "intercooler" (still not installed)). The intercooler pipes certainly aren't as efficiently designed as they could be...they're only 2" OD, and have numerous bends, but no kinks or anything, and we are talking about compressed air here...
My camshafts are aftermarket grind...but theyr'e nothing extreme. I emailed the guy who grinds them (Don Nimi of PDM racing,) and he said that these camshafts should have NO problem seeing 7 psi of boost. Now I know the valve lash is a little out of spec because of the custom shims I got, which could be robbing me of some power, but it shouldn't make that much of a difference.
Straight from PDMRACING.COM, the stock 91 cams are:STOCK 91 Cams - Intake - 207 degrees duration, .350 lift, Exhaust 215 duration, .367 lift.
And the ones I have (stage II) are...Stage II PDM Cams - Intake 219 duration, .379 lift, Exhaust 221 duration, .384 lift.
Could the cams be the reason I'm loosing boost past 4k RPM? If so, does anyone think swapping them out for stock cams would help?
Do you guys think it's time to upgrade the old T3? This has been horribly depressing...$2000 down the drain and she doesn't feel as lively as a $400 chip installed in a stock Audi. If I get a new turbocharger, I have no idea if it will fit, I'll have to fabricate a whole new intake for it, I'll have to fabricate a new outlet pipe for the compressor, AND i'll need to fabricate a new downpipe, which I just got done doing for $260.
Oh jesus. Someone please give me some good news/expert advice! Calling on C-Kwik, Orion, WDRacing, DaveEEE and all you other gurus. Please help!
Hopeless in CT,Marc
