5 lug conversion questions
ILoveMyRHS13
Car: 1990 Nissan 240sx (Hatch)
Okay, these may seem like stupid, noobish questions but I'm just MAKING sure I get everything right before I spend loads of money on all of this stuff. Now, I've heard that OEM 5 lugs are the best product for the actual 5 lug conversion; is that true? Now, after that, would I need anything else besides a brake kit? (I'm really leaning towards Z32) Also, my 240sx is NOT an SE, which means no ABS, so would the Z32 brakes still work with no ABS? Also, could I find Z32 brakes cheaper at a junkyard? So if anyone has answers, any help would be greatly appreciated. Sorry if I seem like I know nothing, but again, I just want to make sure before I spend all of this money.
positron1
Car: Project: 1993 Nissan 240SX Coupe SR
Daily: 2010 Honda Civic Coupe
I have Z32 brakes with no ABS. If you can find those brakes at a junkyard then yank 'em and spank 'em cause in my experience most of these junkyards have no idea what they have or they would be charging alot more for these parts!
94_240sx
Car: 94_240SX
I've never seen calipers on z32s in junkyards. They are the very first part to go. OEM 5 lug hubs are the strogest and offer best fitment. z32 calipers are the most bang for the buck brale upgrade. Try eBay, Autozone and stuff. They are plenty out there, but it's not as cheap as it used to be.
ILoveMyRHS13
Thanks for your help, guys!
ILoveMyRHS13
I also have another question, will I need a special hub puller tool to remove the hubs or are they bolted on or something?
94_240sx
Car: 94_240SX
4 bolts are in the back of knuckle holding the hub. Air tool comes in handy, but still you can remove them with a breaker bar. No special tools needed.
Redline240
Car: 95 240sx
Rather than start another new 5 lug swap thread i'm just gonna throw a few more questions on the fire here. I'm doing a swap on my S14.
So the hubs are removed with just 4 bolts? Does that remove the bearing aswell? It was my understanding that the hub was pressed into the bearing, if i'm correct then i assume the 300zx bearing is the same? And finially, and most importantly, can anyone tell me weither or not R32 hubs are the same? There's some for sale localy that i'd like to pick up but my car is in shipping so i can't compare to see if they'll bolt up. Thanks, didn't mean to threadjack, just wanted to add to the disscussion.
Adam
EthanM
Car: 1995 240sx
im doing the swap too. might sound like a dumb question but am i using the whole zx spindle and hub asemmbly or do i have to have the hubs pressed out and have the 5 lug hub pressed into my stock hub
Redline240
Car: 95 240sx
EthanM wrote:im doing the swap too. might sound like a dumb question but am i using the whole zx spindle and hub asemmbly or do i have to have the hubs pressed out and have the 5 lug hub pressed into my stock hub
I figured there would be a FAQ or a write up on 5 lug swaps here, its one of those things i've known about for years but until now i didn't need the details...
94_240sx
Car: 94_240SX
If you buy z32 or Ichiba hubs, thise 2 parts are already pressed in. ALl you need to do is take old one out and put new one in.
You will follow silmilar steps in this thread to replace hubs.zerothread?id=277821
94_240sx
Car: 94_240SX
You don't need spindle. All you need is rear NA z32 hubs and they are direct swap. Front is different though.
fuse=--action
Car: '91 240sx
Another quick question.
I'll be doing a 5-lug swap and front brake upgrade soon. I don't really want to do the rear swap yet (I looked at the thread, looks like a lot more work than I currently have time to do). So what do I do for the rear brakes?
Oh, and also, can I just press out the bearings from the hubs all around, or will I need the s14 uprights and bearings for the fronts as stated in this writeup? I'm trying to get all the parts together, so it would be nice if I could unexpectedly save some money.-fuse.
fuse=--action
Car: '91 240sx
bump
gumby74
For the fronts, if using the S14 knuckle, you will need the S14 bearing/hubs. The spindle the bearings ride on is a bigger, beafier piece.In the rear, use the complete bearing hub. Wether it be S14, or Z32. I would not recommend mixing and matching bearings unless you have confirmed matching part #'s.
aaronbaird
Car: 1990 240sx
i have a question too hahawill s14 hubs bolt right up to an s13??
gumby74
Front no, rear yes.
smiley405
well im about to do the 5 lug swap too why cant you just http://cgi.ebay.com/ebaymotors...ZWDVW
use that wouldnt that also work?
sidewaysonmy180
Car: nissan 240sx
i done the conversion a couple of times and i went with ichibausa.com 5 lug it was very easy to put on took me about 1 hour for the front for brake lines go to pdm-racing .com stainless steel lines that are bad *** just bolt right on. heres mine before some someone stole my rims
sidewaysonmy180
Car: nissan 240sx
if your going z brakes dont forget there 2 differrent sizes and 2 different materials that there made out of
smiley405
what would you guys prefer the real full 5 lug conversion or the ichiba hub conversion? what is the differnts
sidewaysonmy180
Car: nissan 240sx
there cool for 500 but if u got the cash go with nissan
94_240sx
Car: 94_240SX
sidewaysonmy180 wrote:if your going z brakes dont forget there 2 differrent sizes and 2 different materials that there made out of
30mm Aluminum30mm Iron26mm Aluminum
gumby74
OEM for the conversion pieces with extended lug studs. And that is only because I prefer them there long chunky lug nuts.I received the Muteki SR48's a couple of weeks ago. I like the fact they are not aluminum. Just a side note there.
live_2race
Car: 95' 240sx with SR20de Non-turbo
What about a J30 5 lug conversion? Spindles, hubs, brakes, rotors, everything.
Will 240 springs fit on the J30 front Strut? That is the only way I can see it working.
boriquaS13
Car: 92 240sx
http://importnut.net/300zxbrakeswap.htm
Check this out boys this will answer alot of your questions.This is the site that I used to complete my z32 brake uprade Hope this helps you all out.
alfsnissan
Car: 1995 Nissan 240SX
When you take off the front wheel, remove all brake stuff, take the center nut off the hub comes off the spindle? (Front) Am I right?? Thanks.
blake89240sx
Car: '89 240sx
ive got the same question. my 89 s13 doesnt have ABS and i have free z32 brakes to put on it. will they still work without ABS??
blake89240sx
Car: '89 240sx
hey quick question for you. i have access to free z32 parts. so for the 5 lug swap in the front could i possibly get the whole knuckle/spindle and hub assembly instead of just getting the hub? or does the z32 use a different knuckle? the parts are free so i'd rather get to use those if they work. thanks
