TomsMR2 wrote:if you have to ask.. you cant do it.
I agree completely. and to do a swap like that for less than $5k is NOT going to happen.
Yes, I do have the mounts. They are custom made by application, and the motor mounts without any modification to the existing firewall for a 5.0. The mounts are 4 way adjustable, and allow the motor to sit perfectly level (feel free to check this with a level on mine) within the engine bay for the best possible transmission mounting. Price on the mounts is $875. Not cheap, but custom pieces never are. My first set cost nearly 3 times that just to make and get right, so...
Te 5.0 would not eb able to have power steering or A/C. Ever. There is simply no room for the extra lines and condensor in the engine bay.
Also, the 5.0 weighs 78 lbs more than the stock KA, so you would need to do a lot of weight reduction on the front end to get your handling back. Not as simple as moving the battery and removing A/C. It actually weighs 21 lbs more than my LT1. Aluminum heads will help, but not by much as their weight is set so high in the car.
The Wiring harness is going to run you somewhere between $600 and $1200 because you don't ever use a ford factory harness when doing this as it will short out all of the Nissan equipment in the car. You will also need to dry sump the fuel tank, reinforce the frame in multiple locations, and get a quality rear differential. The stock diferential will crap out before you ever get the car on the street. Yes, even the stock LSD.
