you cannot just remove the bearing with your hands...it has to be pressed out with a hydraulic press, which = $$.$$allensteiner wrote:just popped into my head - take the bearing out and take it to a good suspension shop, ask them if it's shot or just needs to be repacked - might've just lost a few balls and grease - they'll do it for pennies compared to a new bearing.good luck
no offense man, but a warm engine and oil leaks have nothing to do with a broken nissan motor mount.NutriaforBreakfast wrote:My dad and uncle found a bad motor mount this way1) rev up engine 2) see if motor jumps up or moves sideways3) you gotta rev up pretty high sometimes so make sure the engine is warm4) If you have a lot of oil leaks the engine has moved on you
it cost me almost $600 for the hub, bearing, and to have the dealer press it in for me($96 labor). I took off the spindle and took it to the dealer...all they did was R&R the hub and bearing.DevonD wrote:well the car is up in the air right now. Both CV boots look like new. I let my sister borrow the car yesterday while i was working and got it back and now the noise is much much worse. Whenever the axle is under load so either accelerating or im shifting down to slow the car it makes a clicking noise. it speeds up as the car does.
But now Devin, when you say it was a total of about $600. Did you do the work yourself or have the dealership do it? I do all the work on my cars and the only thing i have had a mechanic do is the clutch so i will be doing this one myself as well.
This winter i was actually taking the summer tires off to throw on the winters and in removing the lug nuts one of the driver side studs snapped. so i took the spindle off and replaced it with one from a 95 Max i found at a wrecker. since i didnt have the bearing pressed in could this be why its now giving me issues? Thanks again!
i must have missed the end of this post.DevonD wrote:well the car is up in the air right now. Both CV boots look like new. I let my sister borrow the car yesterday while i was working and got it back and now the noise is much much worse. Whenever the axle is under load so either accelerating or im shifting down to slow the car it makes a clicking noise. it speeds up as the car does.
