gdz1la wrote:what inj size does 41 have i have seen them being red which is 270cc? do the 380cc inj 45 ones fit?
what is the vvt system like on the 41 how and where is it activated?
and do the 45s better exh manifods fit on the 41 heads?
ia have found a cheap 41 to replace the 45 (i cant be bothered doing plastic guides) and the extra room with alt on top will also help
im not buying it until i am sertin the 41's revs superseed the flow of the 45anmd are most of the engines plus the same (i have wired up the 45 already)
but with the v8's the 41 has a awsome rod ratio com pared to 45cheers
A couple of things. You're asking mainly USA people about the VH41 engine. The only VH41 motor they have experience with is the later version (94 onwards) where Nissan started cutting them down to save costs... eventually they even ditched the nice spider manifold !
The VH41 I'm dealing with is out of a JDM spec Y32 Cima (not available to the US or NZ market), and is a first generation VH41 motor. These are the best of them, with the big injectors, strong block, one piece bottom end, spider manifold, etc. Same spec as the Q45 engine, only the timing chain guides are metal, and the heads flow better. It's like Nissan fixed their mistakes with this motor.
I got some of my information from Mirage, who has been involved with the building of an 830HP NA boat motor (VH41DE stroked to 6L) here in New Zealand. This is an experienced person who has pulled these motors apart, and recommends the VH41.
My 41 doesn't have red injectors, they're grey. I'm sure they're the same 370cc (you keep saying 380 ?) rating as SR20DET.
The 41 has a different stud pattern on the exhaust side, so no, custom is your only option.
As I've said all along, go with the VH41... it will save you a lot of hassle and they rev harder. As far as I'm concerned the only thing more desirable about a VH45 (for a project motor) is the extra 0.4L displacement, hardly a big difference.
Also, yep the VH41 has a one piece crank/mains girdle with crossbolts through the deep-skirt block. It's just as indestructible as the VH45. I reckon both motors have an easy 1000HP bottom end... I personally would replace the bearings with greater clearance bearings, then up the oil pressure significantly, but that's all I'd change.
