awesome car mate!!!!Stinky wrote:How hard it is depends on your skill level. It's by no means a bolt in affair. There is a lot of custom fabrication that needs to be done, especially if you want the manual trans.
Some of the fab work required includes:-notch framerail for alternator-weld new engine mounts on the crossmember-replace and move up the brake booster-notch tension rod bracket for ps pump-modify exhaust manifolds to move them closer to the block (this is the worst part)
Custom transmission adapter welded to the transmission and a z32 flywheel with a small spacer.slownslurious wrote:how did you bolt the trans up
