Hehe. I guess it's not for everyone. I refuse to run a tubular crackafold!Alpha_Maverick wrote:bleah, that setup is ugly. But there is something to be said for the beauty of functionality. Form follows function. How are you going to feed the WG flow back into the exhaust? I couldn't really get close-up pix of the outlet side of the WG.
How low, can you go? haha. Sorry, lame limbo joke.Alpha_Maverick wrote:I assume you are going to use a 38mm (based on Vapor's setup). How low do you think you can get the boost to go (at full throttle. I can almost smell the smart@$$ comments coming)?
A couple bucks. I stopped keeping track forever ago. I still know I'm under the cost of a used 350z, car included240sxobsession89 wrote:Nice numbers!! How much did it cost for everything after the motor? Just a rough estimate would be fine.
Apexi Stock thickness, stock 86mm bore.tripleJs15 wrote:codyace:How bad was the creep ? Was is at high psi only ?also what thickness HG are you running ?
Stock GarrettAftermarket Garrett UpgradeandHKS AdjustableHijacker wrote:Which actuator were you using? The one supplied by garret or an aftermarket one like an HKS unit?
It's adjustable. I have no clue what it would do 'as it is' as it doesn't bolt up with changing stuff around.idahotuner wrote:so the one that comes on the unit is set for 10psi ? am i understanding correctly?
I couldn't give you an accurate answer with this. Potentially, but I am not sure.Alpha_Maverick wrote:OK, do you think the 38mm would be able to get the boost down to, say, 7psi (just in case a family member wants to drive)? Or would I need the 41mm?
It may be due to the AVCR? We're running the same psi too....DrifterProdigy85 wrote:I dont know, i never had a problem with boost creep with either the 2871R .64 and .86 housings. Used with stock, megan, and tomei exhaust manifolds. Used with stock elbow and greddy elbow. Apexi AVCR Boost Controller. 2.75" Cold Piping, 2"-2.5" Hotpiping.
That had crossed my mind, but gas flow is much like a fluid, and I'm not sure that the extrude induces that much greater flow through it, then out the WGA.Alpha_Maverick wrote:Cody, your setup exacerbates this situation because of the extrude honed turbine housing. The housing makes it much easier for the exhaust to go through the turbine route, rather than the WG.
That's what I'm doing hehe. I know this will workAlpha_Maverick wrote:2. Go external WG, which results in more WG flow at the same pressure. problem solved.
I used the HKS WGA. It worked ok to start, but eventually failed like the rest of them.Alpha_Maverick wrote:3. I think it might work while retaining the internal WG. Get the dual port WGA from HKS. It appears to have a minimum boost pressure of 12.8psi. I am still working on a way to make it lower (trim the spring? but then I'd have to recrimp the housing... i dunno yet). The dual port setup should allow you to have a lower "flowing" BC, without any problems. Although, it might hurt your response, since the BC would be trying to close the WG, instead of opening it, and if it couldn't build up enough pressure, it would cause the WG to open prematurely.
Euro brand 'Forge' also offers one. I was wanting to try them out, but the external (freebie) and the service cost less......so I knew the lesser cost would definatly work....so I made that choice.Alpha_Maverick wrote:Edit: turbonetics has a dual port actuator ("Designed to be bolted up to the T3 Swing Valve assembly" a little fabrication, and it'll work) that runs at 5-10 psi. This would be even better, I think.
I'd send you a pic, but the server is down right now (DOH!)Alpha_Maverick wrote:I hadn't taken a really close look at the internal WG, so I wasn't sure how it was routed. So it's basically just a hole drilled in the snail, with a flapper valve over it, correct? I was thinking it might have been a separate passage beside the snail. Not really sure why I thought that, though.
There are certainly nice things about an EMS, but there are alot of cons for me as well. I simply don't have the time nor want (i know, that sounds awful) to learn about the EMS and or how to tune my car at the car moment. Maybe when I'm older or am not in school or etc etc....Alpha_Maverick wrote:I think I'm gonna use an EMS, just for the additional options (boost per gear, launch control, "antilag", etc.) That, and I want to be the one to actually "tune" my car. I might blow it up, I might not. That's called "learning". The more research you do before your project, the less expensive your goals become.
Car ran graet for a year, popped a intake gromot up around an injector, went super lean at WOT and ate the piston.MagbeeA4 wrote:very nice on a stock bottom end hope she stays together hope you got head studs at least
the wastegate vent would point towards the firewall. I'll be attaching my flanged pipe to that, running the pipe along the downpipe, and reintegrating it along those lines. I'm thinking of actually using flexible stainless steel exhaust tubeing (much like used on Semi Truck exhauts...flex pipe). TO use for the w/g reroute tube.Emperor_Tha wrote:so I went to import intelligence today. I seen a s13 redtop a with a t28 and on stock manifold with a tail wastegate. Actuator was removed and the flapper was welded shut. Only problem i see is trying get a dump tube welded back to the downpipe or unless its an atmospheric wastegate. But all the exhaust is going to heat up the master cylinder. any solution on this?
