400 ft lbs torque!!!!
bradon123
Car: 92' 240sx se alll options woot 500$$$ good find i think
ok my friend and i built a turbo kit from scratch because were the worst kind of budjet kids out there but after putting a stock diesle turbo on and makeing a turbo manifold with ext wastegate, and no intercooler yet. we made 400ft lbs and like 120 hp at rear wheels with a ka24-et all stock internals besides an eprom chip running 6 psi of boost. i know it sounds like bullsh!t but i can get the dyno sheet scaned and posted. im just so excited. I FLIPPING LOVE 240's. i just cant believe it hasnt blown up yet....or melted
zerepdivad
Car: '90 240sx . '02 Lexus IS300
bradon123 wrote:ok my friend and i built a turbo kit from scratch because were the worst kind of budjet kids out there but after putting a stock diesle turbo on and makeing a turbo manifold with ext wastegate, and no intercooler yet. we made 400ft lbs and like 120 hp at rear wheels with a ka24-et all stock internals besides an eprom chip running 6 psi of boost. i know it sounds like bullsh!t but i can get the dyno sheet scaned and posted. im just so excited. I FLIPPING LOVE 240's. i just cant believe it hasnt blown up yet....or melted
sounds kinda like ...................... but i could be wrong bring on the dyno sheets........
Fenvy
Car: 2005 350Z Base 6MT
are you sure it is not 40lb of torque?
bradon123
no i knew noone would believe me but i will get those sheets up. it was just so fun fabbing all of the **** for it. and we have 3 240's so when something isnt working we jsut grab it off the other one and write minus what were just took on the fender in white marker hahah sooo fun
bradon123
lol hahah yea im sure its not 40 lbs the guy who dynoed the car at derrick dodge in edmonton just about **** himself
Fenvy
dyno means nothing, I just don't think the 2 numbers are possible... maybe broken dyno?
take it to another dyno
BIGT94z
400 ftlbs and 120 rwhp no way thats a huge difference...why stock hp levels and insane torque?
DevilMB3017
Something isn't right here.
I was just reading in another thread the other day about how most dynos use the torque number and a bunch of math to get the HP number...but this doesn't come close to how that write up said dyno's should work...
neverlift
well hp is just an equation of torque,so it sounds to be off. TAKE IT TO ANOTHER DYNO!
still post the sheet and dyno type
and send me that .bin and adr file tonight I'm not boosting yet but would like to look still.... congrats
btw you may want to post the sheet and none of that ghey photochop shop shiot
grats
LayNLow240
Car: 92 240 coupe
i also call bs. how do you get less than stock hp #'s yet almost 5x the stock torque number. just because a diesel makes a ****load more torque than hp doesnt mean that putting a diesel turbo on your gasoline powered car will bring the same results. post up the dyno asap.
halnfl
Car: cars, woman
its a misprint, he meant 120hp and 1400 ft lbs, haven't ya'll seen all the big trucks, geeze guys come on
na3j nitsuj
Car: 1990 S13HB KA DOHC
he misprinted twice? one on the title and the other on the post itself?
thats odd...
need to show the dyno sheet!
chester_ff7
Car: 1996 Nissan 240sx
...................... WOW!! 400 feet to torque? dang! well sound like a whole lotta..... ..... but if you post the dyno sheet you might make a believer out of me! and even if you did get "400lb" it wont mean anything.. you only have 120HPs.... a shock 240 has 155hp, and 156-160 lbs on torque(Twin cam)and like 140 hp, 160 tq on the single cam...... all in all i thing you where better off, without it! all you are doing is running the risk of blowing the engine!!
driftnslide
Car: 91' 240sx Base KA24DE
I agree with all thee above. ...unless you are going to tow the other 240s to the track with that one. then it makes sence and a mildly retarded way.
Mym Mars
Car: G50/94-96 Q45
auto or stick?
S13FX
Car: '69 l20b Dimeski :)
You should have posted this in the KA-T section since it's a turbo.
neverlift
still man a stock ka with a turbo putting down 400ftlbs is crazy real crazy because he said he only made 120hp.
But until proof its looking like you know who cough cough sliders cough cough
killa_snake
A dyno makes Hp numbers out of RPM numbers and Toque numbers. And since its measuring at the wheels this can very depending on what gear its in. In first gear a stock 240 will have 350+ lbs of torque at the rear wheels but in 5th probably less than 100 lbs of torque. But in first gear it will have less RPM than in 5th. HP is a measurment of energy, or power. Electricity is measured in Watts. and its Volts times Amps. 10 volts at 1 Amp makes 10 Watts. so does 1 volt at 10 amps so does 20 volts at 0.5 amps.... same principle with HP. thats why when you gear somthing down to increase torque you sacrifice RPM. Maybe its producing 400lbs of torque in first gear. But i doubt the wheels will be spinning any faster than 2500rpm at redline. All these numbers are best estimates. Don't tell me im off a bit. thats not my point.
Chezedik
Car: 1991 Nissan 240sx
No, the point is that you have an auto, right?
BIGT94z
it has been 7 days and no response. an auto wouldn't matter u can still do a 2nd gear pull or a third
bradon123
kkk sorry guys i havent had my comp working in a bit but im going to scan those sheet asap. and no i wont photo shop em. and yea maby your right about the dyno being off so i am going to take it to another dyno and hopefully get a more reassuring number on the torque. again sorry for the delay.
Chezedik
How many times have we heard on here about people going to dyno shops who don't know their ****?
BIGT94z
numerous times but i dont see how an auto whould alter the dyno numbers.
Chezedik
Well, first off, I would guess that an auto will not have a direct drive gear, such as fourth in our manuals. But more importantly if you start a pull in first, your TQ numbers are going to be higher.
BIGT94z
true but when i dynoed i did a 3rd gear pull. one can simply put it in one take to red line. shift to 2nd then 3rd til redline
bradon123
its a stick. and we ran dyno in 3rd gear it says all this on the dyno sheet including the speed.
BIGT94z
post that bad boy up asap
crzycav86
Car: 93 Nissan 240SX KAT
400ft-lbs and 120hp is completely wrong.
That means you would have 400lbs at less than 1575rpm.
You were probably in the wrong gear, or the guy working the dyno missed a decimal point when entering the numbers for gear ratio or tire diameter or something.
but yeah, what you said is absolutely impossible on a ka engine. sorry.
daconkiftador
Car: '92 Coupe SE, '83 Rabbit GTi, '91 Golf GTi
post pics or
Chezedik
How was the snow in KC?
