40 additional RWHP for KA24DE
WDRacing
Meh, compression numbers indicate a worn motor. It doesn't mean you can't boost said worn motor. I wouldn't crank the wick up too high, but 6 psi is perfectly reasonable. That cylinder won't be as efficient as the other 3, no big deal.
You might have a blow-by issue though, so you'll have to make sure you have the crankcase vented properly so as not to pressurize it under a load.
I wouldn't bother rebuilding it unless you're plans involve tons of boost etc.
gwoods
Car: 2013 Infiniti M37x
1999 Nissan Altima SE limited 5spd
1992 Miata (soon to be turbo)
1965 Cj-5 with 327 v8
2012 Toyota Sequoia Limited
I had thought about dual catch cans I saw on turbo miata!
I'm think build a system that is safe to 12 and plan to run 8 psi all the time. So which turbo the t28 or t3?
WDRacing
Depends on what manifold is available. I haven't seen any for the T25 flange, only the T3.
krash
I think the S14 SR turbo will work well for you. Its a GT2560R (people call it a t28). Its the same turbo as the S15 turbo (which people also call a t28) except for a little wastegate divider doodad. Its a ball bearing turbo and everything.
gwoods
So the first month I don't have a jag payment I will start buying Altima turbo parts 178 is standard checked the book this am. My motor was cold I'll try compression on a warm motor later and see if I get that 10 psi
Dattebayo
gwoods wrote:I'm Irish - German which means I want it done with percision .... tomorrow. I rush things and am also a cheapskate.
What the hell did I just read? :confused:
gwoods
In hit mans article he mentions orange cams looking through my rebuild pictures my cams have orange marks? Is there another way to tell
