sliders »
https://forums.nicoclub.com/sliders-u15796.html
Mon Dec 04, 2006 7:59 pm
c-kwik you might want to go back and look at the dyno sheet before you open your mouth, on that run we hit 270hp and 288 torque .the printed numbers on the curve are what we hit at that rpm and the 273 is the torque at that rpm like i said before. after a little tuning we hit 273hp like i said from the beginning. the only reason i reply back with the words i use are because everyone started to get butt hurt because i wouldnt tell them what settings and exact specs that we did to the motor. I know this is a forum for people to help others WITH PROBLEMS but building an engine that can create alot of hp is not a problem and im not telling you how to do it for free. So be mad, think what you want to think trust me im not gonna loose any sleep over knowing that people are mad. Neverlift the list is still the first post, high comp pistons we change from what we had originally ,stock crank but oy hell yeah did it get alot of loven,arp rod bolts also,rods were worked over,intake work more than theirs,butterflys gone,head ported and polished and a 3 angle valve job which you do to all heads when rebuilding them,aftermarket cam, adj cam gear, square decked the block, complete balance from one end to the other including clutch assembly ,cc'd the head,larger injectors, larger fuel pump ,oh wait damn we forgot the gaskets and the rings damn arent we stupid i dont see how this thing is even running and you dont shim or adjust the valves on a ka24e motor so i guess they ****ed you for that , we have a larger t-body and port matched the intake and the exhuast ports, and you dont get torque from a lightened flywheel you loose it , so like i said before we did more to ours than they did and it only cost around 1,500 because we did it at our shop. Were did you get that= I bought after market stock c/r piston ? Did you hit the bong before you read any of this post, and what the hell is cc flowed the head ,you can cc a head and you can put it on a flowbench to see how much air it flows but cc flowed the head did you just make that one up thats pretty good i might have to use it one day.Yeah right .If your gonna try to bash someone atleast read the post before you open your mouth. Do you even know what blueprinting a motor is?
