How do the powers-that-be at Nissan not realize that <most> people just don't have that type of money to invest in a car that is so high maintenance?
http://blog.caranddriver.com/2012-nissa ... ilability/
OMGA33 wrote: Personally, I would rather walk down the road with a 370Z steering wheel in my hands, than drive a Leaf. Just sayin'.
$36K is pricey but with such a limited range, and relatively few recharging options away from home, I don't see the Leaf becoming much more than a niche vehicle in temperate climates. I'm sure they'll sell a few thousand of them, but I don't foresee Nissan selling as many leafs as they do Altimas any time soon.A33 wrote:I wouldn't buy one, but as others have already said, i'm sure there will be plenty of hippies that will. If it's labeled even somewhat economical, it will sell.
Funniest GD thing I've read in monthsA33 wrote:I wouldn't buy one, but as others have already said, i'm sure there will be plenty of hippies that will. If it's labeled even somewhat economical, it will sell.
Let me crunch some numbers real quick.Eikon wrote: Can anyone confirm?
PapaSmurf2k3 wrote:The leaf battery pack is 24 kWh. I pay between 11 and 13 cents per kilowatt hour. We'll say I get a good deal and use $.15 as a figure. We'll also say that the LEAF is 90% efficient at charging (10% loss in heat through the cable, charging junk and whatnot).
(24kWh *$.15 per kwH)/.9= a whopping $4 to charge it... and that is "playing it safe" with the numbers. It's probably cheaper than that in most places (probably more than 90% efficient at charging, and most places pay less than $.15 per kWh).
The Honda Air concept is a vision of the future of lightweight and alternative fuel performance vehicles; a coastal cruiser for the aggressive lifestyle. Inspired by the modern roller coaster as well as skydiving wing-suits, the Air is powered by a compressed air and pneumatic regulator system. It utilizes turbo vacuums and external air-flow to regenerate tank pressure for extended range and increased boost for an estimated 100 miles. The chassis doubles as the master tank and all components, including seating, are mounted to the central chassis/tank to eliminate redundant structure and reduce overall weight.
Vegetable based polymer panels and fairings protect occupants, maintaining the solid Honda method; safety for everyone. The Air’s cockpit and package maintain the aggressive human packaging of a modern roller coaster aimed at maximizing the open air experience. In order to reduce weight and increase dynamic performance, a hub-less wheel and drive system eliminates the use of heavy drive train components. Glass reinforced seating panels, urethane tire composition and skeletal sub-frame components combine for drastic weight savings. Using a Honda generator / air compressor at home or tire filler at your local filling station, the main tanks and reserves can be filled quickly and safely.
At just under 800 lbs., the powerful anthem of pneumatic propulsion and a character unlike any zero-emission vehicle exemplifies Honda’s concept of fun to drive. The pow[air] of dreams.
I did a comparison for Greg back in the day between a corolla or Versa versus the leaf (or Volt... I don't remember haha).Eikon wrote:
So if you buy a 2012 Leaf, you'll have to drive it until 2026 and have 172,000 miles on it to finally get ahead.
AND.. that's not counting the cost of the quick charge unit that most people will want. It also doesn't figure in the limited use (range of 75 miles per day). On the other hand, the value of zero emissions from the tailpipe does have an intrinsic value to many people.
Now.. as the technology improves, the function should improve and the price should decline. That will narrow the gap. Also, fuel prices are sure to continue increasing, which will narrow the gap even further.
