zerothread/359074JETPILOT wrote:Hands down the Gredddy TT. You should sell the e-manage blue that comes with it and get a UTEC for tuning. The Blue really sucks. The kit should be good up to 625 whp with the right supporting modifications.
I agree. Add the stroker kit with it and youll be pushing some crazy HP.phill Cosby wrote:I have no complaints about my APS system
Single turbo = less lag? What color is the sky in your world?evildky wrote:I prefer the single turbo, fewer parts, cheaper to upgrade, less lag
The turbo dosn't help the other spool up.R350Zz33 wrote:but the supras turbos are set up diffrent thats why they have more lag one turbo spools up then that one helps the other spool up instead of spooling up at the same time from diffrent exhaust pipes idk
That's just plain wrong.evildky wrote:ask a supra owner, how many of those crazy stupid fast twin turbo supras have done single turbo conversions? pretty much all of them, twins spooling faster is a myth, my L28ET and my Z31 both spool faster and make more power than my Z32TT
a propperly sized single will spool faster than duals flowing a comperable amount of ait
JETPILOT wrote:The Supra was a sequential turbo, not a twin turbo.
JETPILOT wrote:The 2jz is an inline motor with the exhaust manifold on one side so it would make sense to go with a large single to make power.Big single turbo's have huge lag, but come on big time over 5000 RPM. If you building a drag car that would be what you would want if you were building a 2JZ motor.
This statement is right. And on paper this is great info. But in pratice it isn't the same.JETPILOT wrote:On the Z the single setup isn't such a good idea. With the crossover pipe you lose exhaust gas velocity with the pipe bends, and there is also thermal/energy loss.
Not always.JETPILOT wrote:Twin turbo's will always spool up faster than a single.
I would call evildky the turbo Z guru and JETPILOT the 350Z TT guy.... But the funny thing is they are both arguing good points that are correct in different scenarios. You guys are both right and if you compare 2 turbos of equal size as a twin setup vs. one of the same size as a single setup, the single spools quicker everytime w/ less lag.... Bigger single has more lag but still spools faster once boost pressure is initiated, there for a TT would be less laggy VS. a single bigger turbo.R350Zz33 wrote:battle of our turbo king (jetpilot) and our know it all nissan guy (evildky) lol good times who will be wrong tine in next time to find out
Assuming ALL the different variables are the same (ex. PSI or flow awarded from each engine/turbo combo is the same, Turbo design, center cartridge type etc...)The general consensus is that turbo's inertia does not proportionatly shrink or grow with the size of the turbo. This causes twins to spool faster and provide more usable power then a single turbo.Artsi wrote:1.3.2 Sequential systemsA more extreme case of variable geometry is sequential turbocharging. Instead of varying the geometry of one charger the number of chargers is changed. The reason for using sequential turbocharging is to widen the flow range for the boost pressure required. Since still only one compressor stage is used it does not necessarily increase the boost pressure.Volvo tested sequential systems presented in an SAE paper in 1991 [1.26] as a part of a methanol engine program. The engine was a six-cylinder unit and the boost pressure target was as usual, slightly below 2 Bar abs.
They state that a parallel turbo system has around 30% lower inertia than a single turbo with the same top end flow characteristics, and thus should have a benefit in terms ofresponse.
i'll take one for that^^^, other than that - i have to wait.Marty T wrote:If interested we have a Greddy TT kit in stock w/intercooler. Price is 589.90 shipped.
Yea for most people this is the case. But others like a little lag inorder to save some serious MPG.R350Zz33 wrote:When I go turbo I dont want high hp I just want usable hp. Know what im sayin
Yea but like I said a larger turbo will cost you 30% more lag then using 2 smaller turbos.evildky wrote:I agree that the smaller turbo's are easier to spin but they recieve only half as much pressure to propel them
You can definitly "say" what ever you want. But I would rather KNOW. I have tried logic to come up with some car theroys but physics is a more solid platform of knowlege.evildky wrote:but I still say it would take less force to spin the larer single turbine to 1000krpm than the 2 smaller ones to the same speed
This is true. I am also assuming both set-ups would produce the same HP and both engines are identicalevildky wrote:and in a well engineered system the difference should be nearly undetectable
Well an engine (when on) is always producing exhaust so "pressure drop" isn't a real issue.I have seen guys running snails near their rear bumpers and the diffrence in the power curve between those who run snails in the rear of the car and in the engine bay is some thing like 500rpm.So running two manifolds instead of one won't make a diffrence and it defintly won't negate the extra inertia that a Single turbo system would bring to the table.evildky wrote:and a single will have less piping, and les piping = less pressure drop
I am aware of pressure drop although I thought we were mentioning spooling characteristics so I assumed you were reffering to the exhaust side of things.But you know what they say about assuming...evildky wrote:rcabrita, I don't think you understand pressure drop, have a read:http://www.gnttype.org/techare....html
I have read this article as well. But Even the writers mention that there will be variables that will affect the numbers.evildky wrote:and here si a great single vs twin artical looks like the twins fow more air sooner but don't continue to spool as quickly as the singlehttp://www.turbomagazine.com/t....html
not seeing your "theory"of 30% come into play
Also it isn't my theroy. It's just some engineer's research.Turbo Magazine: Single vs Twin Turbo Supra wrote:Furthermore, low-end and mid-range tuning could play a role in the power output of the engines (which would only cloud the picture in a small "quick tech" style article).
Well I do still feel that what I wrote perviously still stands I do agree with you also. What an engineer calculates as true might not always work in real wold applications.evildky wrote:I do appreciate the spirited debate, I am by no means an air flow engineer, just trying to pass what I have learend form my real world experience of boosting Nissan/Dtsuns for abotu 5 years now, I feared forced induction for too long, I wish I had given up on n/a and nitrous long before I did
