Here we are again.
Ordered an OEM fan blade, installed it, same vibration! This has begun to be very frustrating as it is a pain to remove/reinstall these components. In the process, the crappy aluminum housing on the fan clutch now has two stripped threads. I admit defeat in all of my previous hypotheses. I am still weary of going back to the original setup since the vibrational loading on the fan pulley, bracket, and water pump is fairly significant - I don't want to further damage anything over time. I intend on keeping the vehicle alive as long as possible (obviously).
So... now what.
Well the vibration I now assume is engine side rather than fan clutch or blade since it is significantly reduced without either the fan components. There's pretty much two options I see now: 1) direct drive fan using a Flex fan setup 2) electrical fan conversion. Since I don't want the fan on all the time especially in cold temps, I'm considering going electrical. Town, the write ups you gave me were definitely helpful. Since RockAuto has the alternators at 110A, I assume that's the stock spec so I'm going to go to Autozone tomorrow and get them to check the load on the alternator with every possible accessory on to see how much spare amperage I have. The fans I've been looking at will draw about 20A for a dual fan option. Tungsten from
http://www.nissanpathfinders.net/forum/ ... us-38-fan/ used a 90A alternator instead of the old 70A so I'm hoping the 110A stocker will be sufficient.
Since there are two options out there I'd like to see any here has anything to say on the matter:
1) Do the dual 12" fans with no shroud (diagonally in accordance to coolant inlet/outlet corners)
2) Do a single large (16"-18") fan w/ a shroud
If CFM's are the biggest player, then is there a big enough concern with flow distribution?
