Vrtgrumpy wrote:Night,
The HKS GT 2835 Turbo does fit because that Turbo is on my car using the stock manifold. I really like this turbo, fast spool and lots of power. I am hitting 20PSI on high boost. I am also running 550cc injectors, Z32 MAF, Greddy Surge tank, Q45 Trottle body and a E-Sports tuned ECU.
This set up is perfect for drifting. HKS said this set up is good for about 420HP. I should be ablt to get it dynoed next weekend. Then I'll be able to let know if it is really at 420HP.
Grumpy
ZERO wrote:I'm really torn right now. I dont know if I should go for the SR or the RB20. I would really like to have an RB.
however I do have a few questions regarding the RB20 swap:
1. Will I have to cut out a section of the hood underframe? If so, should I get a shop to do it, and how much will it cost me?
2. I read on the boards that some modifications have to be made to the driveshaft. What exactly are these mods?
3. Night, you metioned on a post that for an RB25 you can use the oil filters, and some other maintenance parts from the 300zx N/T. Is this true and does it only stand true for the RB25?
4. Is there anyone in the Philadelphia area or close to, that has this swap or that knows how to do it?
I know some of these questions have been answered before, but I want a straight answer. Hope it doesn't bother you guys.
NightXCZ77 wrote:Obviously, no shop sells at MSRP. The yen to dollar conversion is MSRP. Dealers take their discounts off of the listed MSRP to get their pricing. You can still make money selling them at $714 even if you're going through a wholesaler. Greddy probably lets Takakaira have em for about $550 since they'd be direct with Greddy I am assuming.
The RB25DET is a direct bolt in motor with the R33 Cross member and mounts. The transmission mount bolts into the chassis, but is extended farther than the transmission mounts which gives you the option of a spacer or a mount extension.
The Greddy manifold - I have no experience with them. I assume they bolt on just fine, however, you will need a new throttle body if I am not mistaken.
Night
dohctor_yaj wrote:lets get something straight here and start from the way beginning say you dont even have a car or nothing...you want a S13 body 240sx hatch...
to buy a 240 with low miles say 50-70K so that it would be still alive to turbo, you're looking at about $5000 off the bat...then add all the turbo stuff...i dont think any of us here would want to turbo a 140K KA motor...
if you want a hight mileage one so you can add a rb engine in it, it'll b about $1500 and so if you really add up everything, you'll spend about the same amount of money...so don't forget about the cost of the car if one was to start from compete scratch...
you dont need a from facing penlum...its just nice to have one....
550++For a while I wished for a RB26. But now I don't as the rb 25 can be made pretty much an equal to the 26. One can stroke the rb25 with used(or new) rb26 internals. Also from researching skylinesdownunder I have found out the 26 and 25 heads can flow the same and the CC is the same. The one thing you will loose though is the responsiveness from the 6 throttle bodies.End result is a RB26det w/ VTC :thinker Though I am thinking the VTC will be a headache. It's a common failure on VE30DE's and can cost $1000+ to fix. Does anyone know if VE and RB25 vtc's operate similarly?Redline240 wrote:Me too, thats why i'm planning a RB26 swap...Whats your HP goal?
93semax wrote:550++For a while I wished for a RB26. But now I don't as the rb 25 can be made pretty much an equal to the 26. One can stroke the rb25 with used(or new) rb26 internals. Also from researching skylinesdownunder I have found out the 26 and 25 heads can flow the same and the CC is the same. The one thing you will loose though is the responsiveness from the 6 throttle bodies.End result is a RB26det w/ VTC :thinker Though I am thinking the VTC will be a headache. It's a common failure on VE30DE's and can cost $1000+ to fix. Does anyone know if VE and RB25 vtc's operate similarly?
dan240 wrote:it's nice to hear that the RB25det's just as capable as the RB26dett, but i came upon a discrepancy in my research of the engine. I know it might be something that i overlooked, but is there a difference between 96+ rb25dets? do these motors have the VTC??? and is there a difference between the RB25det's or are they all the same? Cuz when i was looking on some sites, there were different camshafts for the rb25det??!??!?!?! i was confused as hell, cuz i thought they were all the same. Anyway 93semax, can you show me the post on skylinesdownunder where it stated that the rb25det head can flow the same as the 26dett? I've got way too many questions, i should shut the wordhole now. Anyway, keep us updated on the rb25det buildup. Good luck and godspeed.
ZERO wrote:well... if I understand correctly its the same concept of the VTEC. You have a high lobe and a low lobe, the low lobe is when it is at low revs and the high lobe is when you are at high revs. If you put cams on it will just be on the high lobe all the time, because there is no low lobe. This makes VTC useless...
Projekt wrote:1000th viewer!
actually nissan has no variable lift as far as i know. they have had VT for years as have many companies. the only variable lift's from japan are hondoo and toyoda.
but BMW is the current god of valvetrains. i personally like the cam specs for rx-7s
neo ddi is for direct injection, neo is just VTC
