haseeb wrote:I was told by the Infiniti service representative that ATF FLUSH is not required at 30K, and it is good to do that at 60K ...He says that it is good for this period ...
A few things to consider:
1. Our collective experience here has shown that the AT in Nissan and Infiniti models are susceptible to early failures if not maintained properly.
2. More often than not, these tend to occur near the 100k to 150k mile range - usually after any extended warranty has expired! If you plan to keep your car for any length of time, then it is good to do the preventative maintenance.
3. The cost of an transmission replacement on these new models is in the range of $3500 to $4500 (includes labor) if you get an OEM replacement - perhaps cheaper to get a rebuild, but with a few exceptions (like Level 10), not likely to last long as a replacement.
4. The cost of 30k preventative maintenance is low compared to what you gain ... significant extended performance. Basically, pay incrementally now and lengthen the life of the transmission so that the cost of that is further out.
5. People doing regular 30k mile AT flushes have extended the life of the transmission by more than 50% to 75% - and, in some cases, longer than that. Well worth it, IMHO.
The choice is, of course, yours!
Z
