300zx to 240sx lsd output shafts?
daniel240
Car: cars/motocross
im getting a lsd out of an na 91 300zx and i know that you cant use the 240 open differential shafts or the 300zx ones. i need to know what cars output shafts will work for this conversion. ive searched and i saw that the j30 shafts will bolt up. is this for all years of the j30? also are there any other cars output shafts that will work? thanks.
14.5drift
J30's with lsd, isn't there a write up on this?
Look in the faq section.
crzycav86
Car: 93 Nissan 240SX KAT
late 95+ model j30's have 6-bolt output shafts.
early 95- model j30's have the 5-star shafts.
You can use the output shafts from the 95+ j30, or the axles from the 95- j30. Or you can get some output shafts from any 240sx with vlsd.
frapjap
'07 Subaru Legacy
Shafts from a 240sx with abs or shafts from an s14 will work w/out changing the axles. Its the least work to make the swap.
crzycav86
Seriously? Even if they're from an open differential? That doesn't seem to make much sense.
frapjap
'07 Subaru Legacy
NO NO! dont use an open diffs!! The internals won't match up! You have to get shafts from a 240sx that has ABS. Any 240 with abs has a lsd diff. THe shafts from it will fit in a 300z diff. Here, this helped me a hell of a lot.http://www.240sx.org/links/installs/lsd/lsd.htm
frapjap
'07 Subaru Legacy
Crazycav: You're saying that the 95 and up J30's have the 2x3 bolt pattern?
crzycav86
IIRC, yes. The late model 95's and newer have the correct output shaft pattern.
frapjap wrote:NO NO! dont use an open diffs!! The internals won't match up! You have to get shafts from a 240sx that has ABS. Any 240 with abs has a lsd diff. THe shafts from it will fit in a 300z diff. Here, this helped me a hell of a lot.http://www.240sx.org/links/installs/lsd/lsd.htm
I know you can't use open diff shafts, I was just playing dumb. I wanted to point out that NOT ALL 240's WITH ABS HAVE VLSD.
My s13 has abs, and it also has an open differential, thus I am putting in a vlsd. Perhaps most abs equipped s14's also have vlsd, but what you said isn't true for s13's.
frapjap
'07 Subaru Legacy
NO its not, sorry that I didn't clear it up. The hicas ones did, but as you pointed out, no, not all of them did. Or else I would have one too : )
s13sr20chris
yeah, i was exited when i got my abs 89 s13. i was seriously let down when i found out the diff was open. you know who started the abs=lsd myth? i think it may have been scc. hard to fault them though they put out a lot of good stuff too.
frapjap
'07 Subaru Legacy
No clue who started that. I was severly depressed when I realized it wasn't there either. Those Japanese fooling us and giving us hope that maybe, jsut maybe we had the lsd in out abs cars, but instead gave the canadians the good stuff.
s13sr20chris
dag gone canadians! j/k.
daniel240
Car: cars/motocross
crzycav86 wrote:late 95+ model j30's have 6-bolt output shafts.
so if i find a early 95 or older j30, the output shafts wont work but the axles will work? so would i just be able to bolt the axles from the j30 to the output shafts from the 300zx diff.?
frapjap
'07 Subaru Legacy
Thats the idea.
yellow_jacket
Car: 95 240sx
Just to be on the safe side, I would order axles from a pre 1995 J30. Mine came out of a 94.
crzycav86
Correct. The output shaft/axle bolt pattern changed sometime in '95, and thus they have both bolt patterns. It's a lot easier to just change the output shafts though.
s13sr20chris
dont all the r200/r220 diffs have the same side gear internal diameter. meaning that all the outputs will swap. this is right? i remember that the internal parts of the big axles(300zx) and the little axles(240sx) are not interchangable.
crzycav86
I have no idea. Sorry.
yellow_jacket
Car: 95 240sx
While it may be easier to swap the output shafts, it is much more costly and no yards want to part with just the output shafts. If you have someone who will sell you cheap out put shafts please let me know as I would love to buy a couple of sets.
J30 axles are cheap and it only takes an extra 5 minutes to unbolt the wheel and unbolt the axle nut.
daniel240
Car: cars/motocross
i tried to get some output shafts from a 240 lsd today from the dealer but they couldnt find just the shaft in the computer. anyone know a part number or anything on them? they are called an output shaft and not some other name right?
daniel240
Car: cars/motocross
also they said the 240s came with 2 different lsd's. can i use the output shafts from either lsd?
crzycav86
daniel240 wrote:also they said the 240s came with 2 different lsd's. can i use the output shafts from either lsd?
Yes. The difference is the rear covers between the s13 and s14 models. s13=4 bolt rear cover, s14 = 2 bolt. The shafts are the same.
Part numbers for output shafts: 38220-92L00, 38220-52F01
Works cited: http://importnut.net/lsdswap.htm
yellow_jacket wrote:While it may be easier to swap the output shafts, it is much more costly and no yards want to part with just the output shafts. If you have someone who will sell you cheap out put shafts please let me know as I would love to buy a couple of sets.
If only things were really that easy.
yellow_jacket
Car: 95 240sx
Why isn't it that easy? I did it. Since you are taking the rear end out already you just remove the pumpkin, then remove the axle nut and remove the axle. Oh yeah, you also have to take the tires off to get to the axle nut. Then reinstall axles and reinstall the new pumpkin.
I can't figure out any reason why it would take you more than 5 minutes to pull each axle once the pumpkin is out. Keep in mind, it only took me 2 minutes to do each one.
crzycav86
Well on many cars(like mine), the axles don't exactly slide right off. For me, it took quite a bit of work to remove the spline from the hub, and this was after soaking in wd-40. However, on other axles that I removed, they came off without too much difficulty.
I just want people who are thinking of attempting this to be ready for whatever comes their way.
yellow_jacket
Car: 95 240sx
If you come across very stubborn axles or stubborn bolts. Get yourself some good penetrating oil. Personally I like PB Blaster.
That is a good point about that some people may have problems with the axles rusting into the hub. If you have a good hand sledge though, you can usually bust them out fairly quickly. Just remember, when you are hitting things metal to metal stuff will splinter off. Therefore eye protgection is a must. I've only got partial feeling in my hand because of this.
s13sr20chris
that and you want to protect the threads on the joint.
crzycav86
s13sr20chris wrote:that and you want to protect the threads on the joint.
Exactly... but if you remove the nut up until the edge of the threads, you can hammer on the bolt/nut and the stress will be distributed more evenly..
s13sr20chris
yeah, i have done that. i would caution against hitting it too hard even then. when i do it i use my large brass hammer because it does not damage the nut/shaft. if i were to use my mini-sledge($8 from sears) then there is a possibility that the shaft will mushroom inside the nut. i only know because i have done it so many times. when you get paid by the job, you work fast.
s13sr20chris
note: if you do damage the threads to the point where the nut wont go on and off but the threads are all still there you can fix. a thread file and a straight file will straighten the metal out but it takes forever.
yellow_jacket
Car: 95 240sx
I Just flew in and out of Newport News yesterday. I was up there buying some equipment for the plant.
If he is just removing the axles or replacing them, it doesn't really matter if it mushrooms them. So in his case, since he getting new axles, he can beat on them all he wants.
