180crafter wrote:Is there any way to change to five lug without changing the spindles in the rear and the control arm in the front? I know that most people change it because it is lighter, but I have a s13 with full suspension and if I change the spindles, then the whole suspension has to be changed.
Any Help is appreciated.
I used S14 front and rear 5 lugs with spindles, and still keep all my suspension. except, S13 control arms with S14 ball joins, I think if you swap the Z32 rear then you will need different suspension.
