well i wouldnt know about the bmc swappin cause i couldnt get the 300zx one to work. the center hole is funky and wouldnt allow proper seating on the connection.Spiffy240 wrote:very nice write up especially b/c im getting all parts together for myself. got 2 questions though:1. Isnt just swapping out the BMC enough for sufficient stopping/better pedal feel?2. Did you buy it (it being the bmc and brake booster) new or used? and How much?
Thanks
lol yea i picked mine up at the local skate park. they have an abundance of them there. lolRavedragon wrote: but they seem to be out of hot chick every parts store i go too seems that hot chicks are on back order these days
those would be nice but while we're on the subject whats the big diff between the two?from a glance they look relatively the same......Nesquick wrote:GTR brakes ftw
the center plug was for the ABS that came in 300zxs and the center plug only came in Aftermarket BMC ie. Autozone cause tey like to cheap out on making the same part for 2 different apps.hilux30 wrote:that center hole is a pain, I dont understand why 300ZX had the center hole pluged, therefore one line for the front and one for the rear, BUT 240sx had two lines for front, and one for rear. I staired at it for an hour and finally decided to make a small line with a male end for the center hole, then the other end of the small line is attached to the main line which that is cut down and a fitting is installed. it sucks but the safest strongest way I could come up with. I could of frade the center line and made it into a male but there was not enough line before the curve to attatch my fraying tools. As far as feel its great as long as you first bleed the master then each corner. But the bigger booster is recomended to help push more pistons and the bigger master.
