I went with tt flywheel, the clutch is larger and will hold up to more abuse and last longer. Mine holds 600 ft lbs of tq. I race my Q45, and I drive it on mountain roads every day to work. I broke the new mounts already, that is why I am making a urethane mount set.
1. Can I replace the transmission mount with the mount for the Z, or do I have to buy the Q45 transmission mount that is more expensive?
I think I used the stock mount. Look at my build log to see how I made the mounts. it gives perfect clearance.
2. Should I lower the transmission by 1/4 inch to accommodate for vibration?
yes.
3. Is it wise to replace the original air filter box with an oval after market breather and relocate the cruise control there?
it will make more room, but not necessary.
4. Which clutch line should I use due to the difference in length between the transmissoin in the Q vs. the Z? I saw that the Rx-7 hard line was used, but wanted to know if I go braided, what would be a good fit if the Z clutch line is not.
I Used a 300zx hard line. works great.
5. How much do I need to shave off in the tunnel in order to accomodate for shifting through the gears? Just want an accurate account so I don't shave down more than I need to.
I didn't shave anything from the tunnel. The Mazworks kit mates the transmission right up to the engine, don't need to do this.
6. Do we need shims for the starter and such for Wes' adapter? Everything lined up perfectly with no signs of much shim use on the thread. If shims are needed what are they again and how many?
Shims are needed if you have the n/a transmission and are using a tt clutch. if you are using the smaller diameter n/a flywheel you don't need a shim for the starter.
The layout of Wes' swap was great. Even though, I still want to know if there were any other minor details that need to be addressed.
BTW, my 1990 Q45 has no precats, and it has a stock USDM engine. and the junkyards have no precats on the early q45's. oh well. maybe I'm just crazy.
I checked my tt clutch disk on a n/a flywheel and it was too big. eh. I think the pressure plate bolts up tho.
