300zx 2+2 TT BIG UPDATE PROGRESS!!!
300ZXttZMAN
You should also look into replacing the trans/alternator/battery harness aswell.
zfan4life
Car: 1990 300zx NA 2+2
300ZXttZMAN wrote:You should also look into replacing the trans/alternator/battery harness aswell.
Gee thanks ttman... now i get to spend MORE money lol
Are those easily replaced with the car completed and together?
Alright update everyone... RODS ARE IN!!!
BigTDogg (MA)
Car: 1990 Nissan 300ZX TT
Easier than an EFI harness, but still easiest with the engine out. A new one is about $200, a good used one goes for about $75-$100.
zfan4life
Alright so a new update.... I am getting readyh to bore out the water passage on the block... i also ordered these parts and they are on the way!
Silicone AAV kit
Timing Belt
Timing Belt Tensioner
Water Pump
Thermostat
Silicone Coolant Bypass Hoses
VTC Springs
VTC O-rings
Cam Seals
Crank Seal
Crankshaft Sprocket
F&R Crankshaft Sprocket Washers
Idler Pulleys(2)
Ramey Idler Pulley Studs
zfan4life
UPDATE UPDATE UPDATE!
So i just got another good chunk of parts in!
Brand new OEM timing belt
OEM Thermostat
New waterpump and H.I. Overdrive pulley
New Cam Gear Valve Springs
AAV Silicone hoses
New crank sprocket
New Tensioner and Idler Pulleys with Ramey Studs
New Silicone Bypass Hoses
ITS CHRISTMAS!
zfan4life
Alright so its getting to the time where i gotta start prepping things to get ready to go back in the engine bay...
so lets start with the valve covers
now after a little cleaning and prep work...
And now its time to cook the ceramic paint...
Fresh out the oven... now i have to wait 7 days? then clear coat it!
Well thats it for the day
zfan4life
Bad news today :(
The head job i had done was crap :( i took it to another shop to have it inspected, and he said they didnt even do valve seats right... so now it has to be redone and all the springs need to be replaced... is the madness every going to end :(
DCaff300ZX
Car: .
1993 CRP TT- Modified
Wow, bad news indeed...I've not had good luck with most people I've had do work on my Z in the past doing even capable work either.
If I was you I'd really spend some time searching out a certified Nissan specialist at the least and hopefully someone very knowledgeable on Z's before having anyone do any further work on your build, it's WAAAAY too easy to have disastrous fubar's occur otherwise...
Here's hoping it's just a small hiccup in your build!
zfan4life
yea a head job is machine work.. so i was hoping a machine shop would be able to handle it ...i guess not
DCaff300ZX
Car: .
I hear ya, in the old days anyone could easily handle the majority of machine work and repairs...but not so much these days.
My NA had the w-pump go bad, and I had some cooling issues of course so I took it to a shop that had done small service for me on the car for years, and where the operator had an NA as well.
They somehow screwed up the w-pump install (leaked immediately) while doing 120K service as well, and when they went back in to re-do the entire job they then broke my radiator and then took a week to find and replace it with a non-OEM, WTF-brand POS..the whole fiasco took over two weeks, and they then tried to charge me for the 120K service on top of the w-pump work (and even tried charging for the radiator as well!) that we'd negotiated to be no cost, since all of the 120K service parts came on and off with the w-pump work.
Needless to say I now do ALL work I can possibly handle, and have a Nissan specialist to help me or handle any major work and will not even consider any other shop.
zfan4life
Alright update update update.
The block is currently being bored out and honed, then we are honing the water passage :-)
The heads are now fixed, brand new valves, springs guides and seals... 5 angle cut on the exhaust and 2 angle on the intake beautiful :-)
The main wire harness is en route however they are having trouble with my sub harness for the injectors so that will be coming later
zfan4life
YAY the new wire harness is in! Also decided to Plastidip the window trim moulding around the entire car... pics to come!
Wheels are also going to be plastidipped
Cleaning the engine bay this week... preparing for the motor! Shouldn't be much longer
Still need to order a couple more parts then im done! First posting Updated with parts
zfan4life
Can anyone else think of anything im missing here? anything else that should be upgraded or redone... shooting for 550 WHP... any ideas from ANYONE?
300ZXttZMAN
zfan4life wrote:Bad news today :(
The madness will end. Once your done and boosting 10psi. Just fight through it man.
zfan4life
Alright guys... so i have been dealing with this shop down in San Diego... its called Speed Specialties on El Cajon Blvd. Family owned and operated... the guy took the time to go thru every step of the process with me, me and my million questions, as well as he sends me photo updates and explains everything to me... you cant really price that kinda of customer service, and man they have been doing a really great job working with me, especially at dealing with my nervousness after the last mishap i had with mechanics lol.
Here are some photo updates!
Brand new springs and guides
Block just got bored out baby!
Next up comes the honing of that water passage! More updates coming soon!
zfan4life
Thanks .. and ill be boosting 20.. if i can hold on until then :)..m just kinda gets depressing that there are so many dishonest people :(
300ZXttZMAN
BigTDogg (MA)
300ZXttZMAN wrote:Click here.
Agreed 100%. Also go easy on the break in. But 20 PSI on pump gas (especially 91 octane) is a recipe for disaster.
zfan4life
Good Info... that changes things alittle bit....
Knock system tuning it is!!!
BigTDogg (MA)
+1 Wise guy (in a good way) :)
300ZXttZMAN
:yesnod
zfan4life
Parts updated. Engine done at the machine shop! Pics coming soon!
zfan4life
Alright time for some PHOTOS!!!!!
Valve Seats before...
Valve Sears after...
Parts Parts Parts
More coming
andre1038
Car: 1994 Infiniti J30t (Sold)
1990 Nissan 300zx (RB Project)
1994 300zx Twin turbo (500hp Daily)
2012 M56s
1998 Infiniti Q45 black on black (Sold)
1996 Infiniti G20
1992 Infiniti Q45 (R.I.P)
i love how i clicked the link that 300zxttman puts up and i am lead to tt.net of octane vs boost with a smiling Z with a FMIC. 300zxttman got a lot of the answers you need buddy. keep up the good work just don't cheap out and cut corners cause it will bite you in the end. i am staying tune to see how your progress goes :) my goal one day is to be at 500whp but I'm gonna work my way up. Stock then 350whp then 400whp then .... etc i am a little by little guy. I wanna drive my z and feel the difference each stage.
zfan4life
andre1038 wrote:i love how i clicked the link that 300zxttman puts up and i am lead to tt.net of octane vs boost with a smiling Z with a FMIC. 300zxttman got a lot of the answers you need buddy. keep up the good work just don't cheap out and cut corners cause it will bite you in the end. i am staying tune to see how your progress goes :) my goal one day is to be at 500whp but I'm gonna work my way up. Stock then 350whp then 400whp then .... etc i am a little by little guy. I wanna drive my z and feel the difference each stage.
Thanks for the follow! I wish i could have done it that way... but when if you read the first posting i got ripped off pretty bad, so i dont wanna go thru this again LOL so i figure do it now and get it done :-)
I am prepping engine bay this week for spray... then hopefully i can have her running by december!
vulcanrush
Car: 93 300zx n/a to tt
probably THE fmic for the z, the TDM one, it'll cost you about 1,700 dollars.
BigTDogg (MA)
It's 100% the TDMWorks FMIC, and it's now $1850. But worth every penny.
zfan4life
Alright folks! Big day for me!!!! got my motor back!!! now its time to put that shizzy together!!!
Crankshaft, heads, block, pistions, Upper plenum
Dont mind that box on the bottom, it was waht the machien shop used to put parts in.
Block out of the bag and on the stand!
Welded counter weight :-)
More to come!!!!
zfan4life
Alright guys... its been a minute since my last posting...
Freshley rebuilt heads with new valves, springs and guides
Prettied up the eninge for the shows...
Completely built motor balanced/welded crankshaft, bored out water passage!
Here are the updated pics!!! If you have questions hit me up!
new valves guides and springs
Fresh from the machine shop!
Yummy!
Was bored so i painted these
Dr z motor mount on the bottom BDE ON TOP!!!
This is what Dr.Z tried to pass off as my turbo Oil Cooler!!! LOL FAIL Stillen cooler on the way!
Very Bored
Wiseco pistons , eagle Rods, ARP hardware, and ACL Race Bearings
First comes love!
Then comes marriage!
and then... HAPPILY EVER AFTER!
Would love to hear your thoughts!!!
Retro-Cow
Car: 1993 300zx TT
zfan4life wrote: Prettied up the eninge for the shows...
Prettied up indeed! Digging the color scheme.
What color do you plan to do the Throttle Cable Cover?
