They "rebuilt it" and converted to Twin turbo for me. I go pick up the car and don't even get home and it breaks again (idler pulley fail). The car gets towed back to the shop where he attempts to fix it again...long story short i get the car home...driving down the freeway throttle sticks and i have to tow car home. get it opened up and there is a bolt jammed in the butterfly of the throttle body. upon further inspection, the "555 injectors" i paid for turned out to be stock injectors and half of them were failed and not working. So i pull them out and decide to see what else is wrong.
By the end of my inspection, i was surprised the car ever made it down the street. He took a stock NA motor and threw turbos on it, and ran with the money.
PARTS UPDATE!!!!
importpartspro.com Wiseco Forged Pistons .020 molycoated skirt
Eagle Rods with ARP2000 Bolts
Brand new rebuilt heads (new valves new guides, new seals, 5 angle cut exhuast 2 angle raidus intake)
Brand New 555 injectors
JWT ECU (mapped appropriatly)
NisTune Coming!
GSP-600 T28 turbos
DNA Motoring Big Radiator
Silcone Heater hoses are in!!
GSP FMIC with 2.5 inch piping all the way thru
SSQ Blow Off Valves
Stock Turbo mani
Divorced Downpipes
Straight pipe all the way back
EGR Delete
Prosport EVO Digital Boost and Water Temp Gauges
6 puck high pressure clutch
Lightweight fly wheel
No Name Underdrive lightweight crank Pulley
Short Throw Shifter
Full Intrax Suspension all the way around!
New water pump
new idler pulleys
Ramey Idler studes
new tensioner
new oil pump
new crank gear
ARP Main Studss
ARP Head Studs
Silicone Radiator Hoses
BLOCK WORK: Bored and honed cylinders (.020), align honed girdle, crankshaft polished and balanced, crankshaft counterweight welded, all surfaces decked, water passage honed out.
485 LPH Walbro Fuel Pump
Nismo OilCooler with silicone hoses
...probably forgot somethings... will add them in color a
Stock exterior for 2+2. SLEEPER STATUS BABY!
Complete interior overhauled. New Seats front and rear, all the twead panels removed and synthetic leather installed (2 tone)
JDM Clear Taillights
JDM Clear Side Markers
JDM Clear Front Markers
still needed!
Steel Braided Brake Lines
Silicone vacuum hoses
Full Dyno Tune upon completion of build!
..And im sure im forgetting something here...will update!
Some pics of my Baby!
Whith your fat A$$
New Heads!
Old tweed trim panels
New leather trim panels :-)
A comparison, new on left old on right
New leather seats
New Din gauges hidden beneath the radio (prosport evo digital gauges)
Short throw shifter with new boots
New 555 injectors!
Some of the screwups of DR. Z Tuning - this guy is good at stealing your good parts and putting them on his car and giving you crap!
Lovely Crank pulley
Tools he left in the motor
Busted cam gear on my "Rebuilt TT Motor". He couldn't build a house of lego's!
Check out the "awesome" grinding job on the mount support, and the stellar mount itself
hmm... NA DOMED pistons on a "tt" but .."its suppose to be like that"
he put and new gasket overtop an old gasket...Anyone wanna guess where the exhaust leak was??
