I didn't notice until I was stupid enough to scratch two spots and they are HUGE....
sigh, the dealership won't fix it for me. I spent $200 to fix the paint.
Qashqai wrote:Why didn't you use a 14$ touch up paint?
If I were you, (after spending 200$)I would stick a 1" by 1" 3M clear tape over those two spots to prevent it happening again. Who knows maybe a service guy wants to replace your wiper for free and lift the arm? or your father in law/friend comes to visit you and tries to lift the arm before the tonight's freezing rain (happened to me many times).
FYI for the future, searching works. This has been talked about.skit2900 wrote:Does anyone know why Nissan chose to design the wiper arms on the new rogue so that they cannot be lifted away from the windshield for cleaning, maintenance or convenience when we are expecting a snow or ice storm? I spoke to the dealer about it and he told me that after you turn off the engine you push the wiper lever to the mist position twice and it will stop the wipers mid cycle. Ok that works but I just can't think of a single reason why it was designed this way. Every vehicle I've had previously, you just lifted the wiper arm away from the window.
Try one more time to clean it with isopropyl alcohol or replace with TRICO. I have trico on the front which I replaced when I hit 30k miles and they're not bad. Here's the link for the rear wiper: http://www.carid.com/2015-nissan-rogue- ... 40696.htmlcolonelcasey wrote:My rear wiper on my 3-month old Rogue just isn't cutting it for me in the crappy winter weather we've been having. It's skipping a bit and not fully cleaning 1/3 of the wipe area leaving residue behind. Happens even after clearing the ice and trying to clean the blade. Anyone have suggestions on a better rear windshield blade? Also looking for the correct size of it because I can't find any reference to it.
The alcohol trick worked. Found an alcohol pad, wiped my rear wiper, and now it wipes perfectly again. Worked way better than a wet towel or car cleaner and definitely helped for my drive home with all this melting snow/salt on the roads. I'll keep a stash of alcohol pads in the car for future use.Leo2005 wrote:Try one more time to clean it with isopropyl alcohol or replace with TRICO. I have trico on the front which I replaced when I hit 30k miles and they're not bad. Here's the link for the rear wiper: http://www.carid.com/2015-nissan-rogue- ... 40696.htmlcolonelcasey wrote:My rear wiper on my 3-month old Rogue just isn't cutting it for me in the crappy winter weather we've been having. It's skipping a bit and not fully cleaning 1/3 of the wipe area leaving residue behind. Happens even after clearing the ice and trying to clean the blade. Anyone have suggestions on a better rear windshield blade? Also looking for the correct size of it because I can't find any reference to it.
kdawgud wrote:Has anyone purchased wiper blades for their 2014 Rogue? I have really liked the Bosch Clear Advantage blades for my other vehicles, but neither the Bosch website nor amazon.com show any compatibility with Bosch blades. Are there really different wiper blade connector types or am I safe as long as the lengths match? I compared my other vehicle's bosch blade with my Rogue OEM blades and the connector looks nearly identical, so I'm surprised to see they don't show compatibility. Has anyone tried these or other Bosch blades on their Rogue?
Wow. Great idea. Just bought this on eBay. Only $5, for 2m.skit2900 wrote:One more thing: To everyone concerned about accidentally scrathing their hoods from lifting the wiper arms too far, I bought those black rubbery door edge guards (the roll type not the individual strips since they won't be long enough) that they sell in Auto Zone or any auto parts store. They fit snugly right on the rear hood lip between the wipers and hood itself. They have a light adhesive on the inside section of the molding to hold them in place securely. This prevents anyone (gas attendants, car wash attendants, etc) from instictively yanking them up to clean the windshield. As an added precaution I also lowered the parked positon of both wiper arms by one notch which actually helps keep them from being raised by accident because the hinge of both wiper arms are just a tiny bit further under the hood line which serves as a "block" from them being raised.
I'm going through the same issue. Everyone sells wipers with the "J hook" thing in the center, but on the 2014+ Rogue the hook thing is offset to the side. This makes it so the driver wiper stops a good 1-1.5" shorter of where it should stop, if you use an aftermarket replacement. Some people might say that's a minor thing, but it irritated me to have a 2-2.5" wide area on the left of my windshield not getting wiped when the factory wipers go way closer to the edge of the visible area.RGOLD wrote:I can't seem to find the exact wiper 26" and 17" blades for the Nissan Rogue. The Original wiper blades have the side connection where all standard blades have middle connection. Does any one already replaced the original blades?
I think the OEM blades are refillable. You just need to go to your dealer to order the right refills. Seems that the part numbers are 288954CC0B and 288954CC0A. Nissan Parts online lists them to be $11.45 a piece.tsumeone wrote:I'm going through the same issue. Everyone sells wipers with the "J hook" thing in the center, but on the 2014+ Rogue the hook thing is offset to the side. This makes it so the driver wiper stops a good 1-1.5" shorter of where it should stop, if you use an aftermarket replacement. Some people might say that's a minor thing, but it irritated me to have a 2-2.5" wide area on the left of my windshield not getting wiped when the factory wipers go way closer to the edge of the visible area.RGOLD wrote:I can't seem to find the exact wiper 26" and 17" blades for the Nissan Rogue. The Original wiper blades have the side connection where all standard blades have middle connection. Does any one already replaced the original blades?
Are the blades re-fillable? I may have to go that route. Unless someone has an idea on how I can adjust the travel distance of the wiper arms (which I don't think is possible).
Edit: Found this but might as well just buy the OEM part from the dealer at these prices... http://www.amazon.com/gp/product/B00509 ... automotive My dealer carries the OEM blades for $19.95 each.
