2JZ Swap DVDThe parts list and chapter outline are on this link.http://store.driftingshop.com/2jzs14swdvdp.htmlfuzionfuka wrote:how much work is really involved in swapping in a 2jz? What i mean is i know you need the following things:
-mounts (tech2)-driveshaft (tech2)- crossmember (tech2)-custom wireharness(makes it so much less of a pain(tech2)-Custom heat and a/c lines (because i want a/c)- cusyom aftermarket radiator (tech2)- 1jz-r154 trans ( getting 1jz so i dont have to swap bellhousing)
anything else that im missing?
all i can say is driftshop said it all. Tech2's DVD but they dont outline it like that. they name evey damn part i will need to complete this set-upDRIFTING.com wrote:
i saw 1100whp KA-T , at MIR this past SAT.....mannnnnnnnnnnnnnnnnnnrcabrita wrote:Hey I remember you Fuzion. You got reemed but the 2jzswap.com guys for not searching.
Yea budget is always an issue. But Y run a turbo when you could order your swap kit? (CM,TCM,axles and mounts)
because once you order the swap kit you still need an extra 2000-3000 in parts and etc......rcabrita wrote:Hey I remember you Fuzion. You got reemed but the 2jzswap.com guys for not searching.
This is tru but once you go turbo with your KA your officaly $1500 farther from the 2jz swap. You could keep the intercooler but I guess... But it depends how bad you want the swap. So far I spent about 5k in parts for my car to prep it for the swap. And once I put the wheels on, roll the fenders, and install the brakes I will offically start saving for the swap.fuzionfuka wrote:because once you order the swap kit you still need an extra 2000-3000 in parts and etc......
you can b.s all you want ......that **** was at Pinks All Out, i saw it with my own eyes and its not even 75% of its potential. i was told the car should make 2000whp once its track ready. i took a picture of it and the motor with the body flipped up so you can see the motor. should be a mid 7 sec car.bone_stock_240 wrote:
I call
Feel free to prove me wrong.
Hmm ok well he could of told you that it was a D15 running 1000 psi... Whould you believe that?fuzionfuka wrote:you can b.s all you want ......that **** was at Pinks All Out, i saw it with my own eyes and its not even 75% of its potential. i was told the car should make 2000whp once its track ready. i took a picture of it and the motor with the body flipped up so you can see the motor. should be a mid 7 sec car.
see you guys are thinking a street car, this is a drag car fiber glass body and etc. Its a 4.0 liter ka, the block is a bit taller than a normal ka. if i can email the pic i took can you post it for me. big *** tubbed wheels and all.rcabrita wrote:
Idk dude. Post this picture (which will do nothing for those claimed horsepower #s, unless he had his dyno sheet stamped onto his valve cover)
BELIEVE NOTHING YOU HEAR AND ONLY HALF OF WHAT YOU SEE!(especially before posting possible nonsence)
If it were running 8's or 9', I'd agree but its running mid 6's... that takes a ton of power.rcabrita wrote:And I also still don't believe the 1600whp 350z post either. People can type what ever they want but until I see dyno sheets I will not be happy
So what exactly makes it a KA? The block is different, the head is different, the bottom end is different. Maybe it has the KA valve cover or something.fuzionfuka wrote:
i am just surprised that anyone even did this to a KA motor because people swap in sr20 all the time.
there are 4000whp integra's and thats a smaller motor than the ka. why is it that im a liar......here is the type of body i was talking aboutfuzionfuka wrote:its a KA but it has one of those big *** solid dart "type" blocks in it. not sure of brand by no means was it a stock size motor , i spoke breifly because they were starting the races so i left to the stands to watch
