RCA »
https://forums.nicoclub.com/rca-u54941.html
Fri Jun 15, 2007 3:27 am
Well there both great motors and can handle **** loads of boost. But bang for the buck... 1JZ all the way! I saw motor sets for the 1J for $1,800 with the harness ecu and 5 speed. And if you buy a chaser 1J you wont even need the transmission extention, but if your not that lucky for 1,800+250+450 you will be all ready! Then the swap kits and some pataince you will be ballin!
And in terms of strenth...The 1JZ block is identical to the 2j. The only diffrence is the stroke, and the bore is the same. People accually swap the blocks of their 1JZ with a 2JZ block and create a 1.5JZ They say that the 1jz head flows better so if any thing ever happpens to the 1jz block you could create a monster!
Whom ever mentioned the 900whp...600whp will give you 10sec Qrts (food for thought)Plus at 900hp you will need to do some SERIOUS chassis work so the car doesnt turn it self inside out
Modified by rcabrita at 10:21 AM 6/15/2007
