decided to sell for $15,000 OBO.
if you are interested make me an offer, don't have time for this anymore and do not want to invest anymore money into a car now that I got my second child due in march.
car is not complete but I have invested double what I am asking for it in parts alone. this is being sold as a project car.
not street legal yet. in California it will not pass smog, the Dart pro1 200cc heads do not have the passage for the exhaust gas for the egr valve to work.
most of the original parts listed on the first page of this thread are still accurate. changes are the top end now is the tpi fuelinjection with the edelbrock baselate, customized throttle body with welded in aluminum air foil that was shaped to help air flow, 60lb injectors in anticipation of turbo/supercharger.
car is running the 91 tpi speed density setup,
car has mustang fr500 rims 17x9 up front with 255/45/17 kumho ecsta spt tires and 17x10.5 with 285/40/17 in the rear.
the seats are fixed and do not slide. if you plan to use the seats I would be happy to alter the mounting points on the customized brackets I made to fit you(took originals and altered a bit to set the seat lower in the car). enigne is now mounted with moroso solid motor mounts.
hardware from Moates.net , the AUP1 that does data logging, real time emulation, and burns chips.
link for the AUP1
http://www.moates.net/apu1-autoprom-pac ... l?cPath=64
ecu has the gp1 adapter from moates.net as well which makes it very easy to swap chips.
ecu is custom mounted behind the glove box and set up to drop down when bolts are loosened giving access to cover for easy access for tuning, also easy enough to take off the glove box.
have new starter, exhaust manifolds used for the turbo setup, the chinese gt45 turbo that had parts swapped for real garret parts, 4in down pipe and some other exhaust pieces for the 4in exhuast.
with the close to 9.0 compression might be a little over I would expect around 350 hp from this setup with out the turbo, with 6-8psi of boost could easily hit 500-525(could obviously do more but told not to exceed 550 with this block). 2 bolt mainblock, small journal 327 will all forged internals, only thing reused was block and the original forged crank which was refinished and now .02 under as result, cylinders are .06 over, eagle h-beam rods and icon pistons(were the keith black forged pistons when I bought them now but those are sold as ICON now).
has a custom gauge panel with around 1200 dollars of gauges(including AEM WB afr, Stewart Warner MPH, the rest are autometer).
