240sx
itzmatthewxP
Car: nissan 240sx
i need help guys i have 240sx chassis one manual and one auto. right now i'm swapping everything from auto chassis to the manual chassis since the auto chassis is rotted out with rust. i was comparing the harness in the engine bay on both cars and i notice a couple of relays and sensor plug wires not present. the auto came with an electronic control box where the manual chassis has no harness plug or space for it. i want to know what is that box for? i'll try to put up picks sometime next week but now i'm stuck. and also anyone out there know where i can find the full harness to do a complete swap from auto to manual?? thanks
airman86
there is a sticky on this forum that has everything you need to know about the auto to manual swap. those relays are probably there for the auto transmission, which you won't need anyways.
moemoney240
Car: 90 240sx
airman86 wrote:there is a sticky on this forum that has everything you need to know about the auto to manual swap. those relays are probably there for the auto transmission, which you won't need anyways.
Where is that sticky at id like to see it
dallaceseiuli
Car: wich one
its the first thread zerothread/187181
itzmatthewxP
Car: nissan 240sx
the link is good but still doesn't tell me much about the electronic control box, and i can use back the engine harness for manual? i'm still confused.. cause i was refering to the relay fuse box in the engine bay the setup from the manual and auto is different.. sry for the trouble
