 240sx automatic to manual transmission conversion s13 and s14First  1 2 3 4 >  Last
180fan
Supporting Member
89 fastback
San Francisco
12-14-2002
s13 from our very own mod tenkawa_akito
http://forums.nicoclub.com/zerothread?id=77784
S14 from nighkid86
http://forums.nicoclub.com/zerothread/181139
Now this is stickied for both s13 and s14 owners. You post a question about this, I'm going to lock it down. Learn to use the search function or look at the top of the page maybe?
1. Search
2. Lurk moar
3. Don't post till you've searched
4. Don't forget details. We're not mind readers over the internets.
nightkid86
97 S14 SE
Waxhaw NC
12-2-2005
 « Re: 240sx automatic to manual transmission conversion s13 and s14 (180fan)
Supplement on removing a flywheel:
There are a few ways to get an automatic or manual flywheel on or off.
The easiest by far is to have an impact gun. A quick ziiiip and the flywheel is on the ground. If you don't have an impact gun the flywheel will spin as you try to take it off, you can attempt to brace the flywheel using screwdrivers and such, while holding the crank pulley with a 27mm socket.... or you can use this secret:
EASY WAY TO GET ON AND OFF A FLYWHEEL: upon doing a clutch swap a year or so after my 5 speed conversion, I ran into a really easy way to change the flywheel. Basically you get a new bolt (and possibly a nut since the a/t flywheel isn't threaded) that will fit into a hole on the flywheel (the hole not used to bolt to the crankshaft) and use a bellhousing bolt. Run a chain between the two bolts as shown in the diagram below. it doesn't matter if the chain is too long, the excess can just dangle. Put the chain on and then turn the flywheel to add tension to the chain. The chain will now keep the flywheel from spinning. This works great to hold the flywheel if you don't have an impact gun. Wrench away.
http://www.cardomain.com/id/nightkid86
Hijacker
240SX Moderator
'92 240sx Convertible
Olney IL
8-13-2003
The chain idea is an awesome idea. Usually I've just had someone hold the crank still on the front while I use a breaker on the rear. If you have an impact though, you should be able to get the bolts off with no problems.
-Bart
Quote »
Hey wait. My balls don't hang too low yet
Stacey L. Childs, NICO Mom
jr_ss
Cruis'n for a Bruis'n
95' S14
Venice Fl
11-26-2005
I would like to add some info to the S14 procedure.
I'm getting ready to do my swap and in taking some conversion steps early I found that when drilling the hole for the MC, a perfect size to use is 1 3/8th's hole saw. It's slightly larger (about 1/32nd larger) than the protrusion on the rear of the MC. This size will allow the rubber to be pinched inbetween the bulk head creating a "waterproof" seal, not that any water would get there but it'll also help with the road/engine noise in the cabin. I would imagine that the S13 MC would be similar if not identical to the S14 and use the same size hole saw, but do not hold me to that as I do not have an S13...
Glenn
l 95' S14 l S14 Sr20 l Whiteline l Cusco l Z32 brakes l 350z Rays l
l Jdm Aero l SPL l Fujitsubo l RPS l Apexi l DSS l Defi l Tomei l
OG ZMFL member #1
Soravia
1991 240SX Coupe 1992 240SX SE Coupe 2003 SE-R Spec V
Jacksonville FL
11-18-2005
I used a steel pipe on the rachet to get leverage and loosened it from a good angle to minimize the flywheel spin. I didn't have help so I used another rachet and pipe to hold it from at one of the bolts. On the last one I re-bolted the one before with anti-size, plastic/brass washer to make hold for the last one. It was tricky but did the job for a poor man. (actually the air compressor plug was broken)
1991 240SX Coupe all stock - Wrecked.
1991 240SX Coupe VQ30DE project - Sold.
1991 240SX Coupe Celica front seats - Sold.
2003 SE-R Spec V - Sold.
2004 RX8 Sport - Sold.
Next pick - 240SX? RX-8? RS200? Impreza RS???
silman180
93 240
sioux falls sd
3-17-2007
 « Re: (tenkawa_akito)
hey im new this forum stuff can you give me some pointers on posting questions i see your online
xTearsFallForeverx
1990 s13 Fastback
Lousville KY
5-28-2004
the best way is if you can get at least 1 bolt off, get a long box wrench and bolt the closed end to the flywheel. use that to hold the flywheel while you take the others off. worked great for me. was my grandpa's idea. man comes up with anything. made a valve spring compressor once out 2 pieces of wood and a jig saw. lol
1990 s13 now>>KYB GR2, Eibach Sportlines, 2 1/2 catback, OBX N1 Style muffler/ Walbro 255/ Fidanza Flywheel, underdrive pully on crank, MSD Blaster 2 Coil.
drewc87
00 celica gts/93 s13/98 cbr600 f3/89 toyota p/u 4x4/04 crf50
LAnsdale PA
9-16-2004
 « Re: (xTearsFallForeverx)
is an 89 5sp sohc trans and a 93 dohc trans both the same? and does anyone know if an 89se has abs from the factory?
andrew_conolly@yahoo.com
10sec240
240sx
Beaverton OR
4-4-2007
Hey how much would an s13 full manual transmission swap cost on a 1989 240sx?
j-nasty
1997 240sx
Inglis FL
11-12-2006
 « Re: 240sx automatic to manual transmission conversion s13 and s14 (10sec240)
Quote, originally posted by 10sec240 »
If you get someone else to do it for you I've seen the prices go up to around $1,400.
dnoiser
nissan 180sx stage 4
pompano beach fl
4-27-2007
 « Re: 240sx automatic to manual transmission conversion s13 and s14 (Soravia)
looks nice and clean im impressed how easy it is to find a good body here in usa (im german) our datsuns and nissans where all f"{+ UP
I HAD A 96 240 sx se before i bought the 180 everyone told me i shouldnt haha but damned i love fastbacks
btw i never touched the techical **** before i came to usa but this nissans make u a grease monkey hehe
i think we all love it ;-)
have a good one
btw im always interested in tips and hints to make it tight
dosusx
brooklyn ny
6-2-2007
So if i find a mint s14 auto owned by a grandpa or grandma, this swap will make it exactly like a manual? its the same setup and parts how the manual is? it wont have any problems once i swap for a sr20 and new trans later?
hookup
240SX VERT
sanleandro ca
6-17-2007
 « Re: 240sx automatic to manual transmission conversion s13 and s14 (nightkid86)
for less money and faster shifts you can get a shift matic
http://www.ipttrans.com/nissanauto.shtml#main
hookup
240SX VERT
sanleandro ca
6-17-2007
 « Re: 240sx automatic to manual transmission conversion s13 and s14 (dosusx)
look at the shift matic
iseenem240SX
I weigh 240 and drive one
1998 240SX SE
Los Angeles/Ventura County CA
8-23-2005
 « Re: 240sx automatic to manual transmission conversion s13 and s14 (hookup)
Anyone running a '95 5-speed transmission on a 97-98 240SX? After auto ECU swap to a MT ECU, CEL came back on after 100 miles.
whenthesunsleepsx
long island NY
7-9-2007
assuming that i do the labor, can someone give me like an estimate on how much a manual conversion would be for my 91 s13 240sx coupe, or if anyone did it themselves how much it cost them, i'm trying to get an idea before i start trying to pull this off...thank you
bone_stock_240
1995 Infiniti Q45
Toronto Ontario
1-25-2007
 « Re: 240sx automatic to manual transmi ... (whenthesunsleepsx)
I have seen people buy complete swaps for between 200 to 500 bucks. Any more than that, and you are getting ripped off. Welcome to Nico!
^^Click for nude pictures of asian girls^^
Quote, originally posted by JimmyMethod »
Plus she'd probably start bitching and crying about how "I wanted you to put it in my *****, THEN my ***, THEN my mouth! You ruined everything! My life is over!"
I wouldn't want to deal with that ****.
SWAT Team S14
Allentown NJ
8-14-2007
nice idea.....wish i woulda read this before........
KnoxVegasS13
91 Nissan 240sx w/S13 Triple Projection Conversion and SR20DET
Knoxvegas TN
5-1-2007
I got mine for like 500 bucks.
91' 240sx SR20DET
marcus 23
95 240sx
queens ny
9-19-2007
i resently had someone install an sr20det s14 into my 95 240.The car was auto i bought a front clip and gave everything to him and ever since i got the car back it's bin problems.The wipers and reverse light dont work the the car goes into safe mode if the car is left to idle...i need some help with the wiring
JDS Performance
NICO Sponsor
Charlotte/Concord NC
6-4-2006
 « Re: (marcus 23)
I have a DVD on the AT-MT swap - its pretty dang detailed too!
http://www.240SXTECHDVDS.org
KGB
1989 Nissan 240sx & 2007 Ninja 650r
Suisun City Ca
10-8-2007
hey guys, I seen this topic and was already wanting to post a topic on tranny swaps. First, I am assuming that the creator of this post wants to know the price on swapping a manual tranny into their 240. Of course it all depends on whos doing the job. Some guys can charge you an arm and a leg, and if your lucky some guy will want to sleep with your girl either way its one hell of a price for the job. The tranny alone can cost from a few hundred to even a grand or so.
My question is though, can the trannys from 89-99 intermingle? Cause right now my auto tranny on my 89 240 is shot, and want to swap a KA24de later on.
JDS Performance
NICO Sponsor
6-4-2006
 « Re: 240sx automatic to manual transmission conversion s13 and s14 (KGB)
99?? 98' was the last year.
Yes the trannies will work on each other - the s14 ODBII has the crank angle sensor ontop the bellhousing - so there is a hole up there
where the s13 does not use this sensor - you can swap bellhousings the gear box is the same - the rear housings is the same
you can no use the auto speed sensor in the 5 speed - and you can not use the s14 speed sensor on a s13 or vise versa
It cost me around $1500 for my swap - but I did alot of upgrades while I was doing it all - plus I installed the 5 speed brake booster/pedal ect I went the extra mile to do it right.
matthunter8819
92 nissan 240sx coupe
College Station tx
9-11-2007
 « Re: 240sx automatic to manual transmiss ... (JDS Performance)
thanks for the help
JDS Performance
NICO Sponsor
6-4-2006
 « Re: 240sx automatic to manual transmiss ... (matthunter8819)
no problem LMK if you need anythig else!
joshds25@yahoo.com
skylinegtst93
rapid city sd
11-13-2007
good infor
smoothfilipino
nissan 240sx
chatanooga Tn
11-21-2007
hey i have a 98 nissan 240sx se. and the only thing iv done to the car is suspension. i want to get a swap from auto to manual. does ne one know how much that would cost plus what parts i need to buy
JDS Performance
NICO Sponsor
6-4-2006
 « Re: (smoothfilipino)
My 5 Speed Swap DVD is your best friend
AH240sx
10-21-2007
Omg it sucks not having a garage. Nor having friends who put cars in garages.
JDS Performance
NICO Sponsor
6-4-2006
 « Re: (AH240sx)
rent a storage building - thats how I started out
JDM Silvia
240sx
OH
11-25-2007
 « Re: (JDS Performance)
yeah those are very usufull info.
nyteryda_irv
'96 S14
Ft Meade MD
10-26-2007
not sure if asked already, but im trying to mingle the s13 tranny into my s14. what sort of problems, if any, would i run into with that swap?
JDS Performance
NICO Sponsor
6-4-2006
 « Re: (nyteryda_irv)
Quote, originally posted by nyteryda_irv »
You will need to use the s14 VSS (vechicle speed sensor)
- if its a ODBII car then you will not have the crank angle sensor - as the s13 tranny does not have the hole on top the bell housing for it - car will still run and all - but it may throw a code and keep you from passing emissions test.
Thats about it really
nyteryda_irv
'96 S14
Ft Meade MD
10-26-2007
Thanks man, I really appreciate it. Its the base model.
JDS Performance
NICO Sponsor
6-4-2006
No problem man - base model doesnt matter in this case
I few people have had issuses with the auto TPS on a 5 speed swap - but I have never had any issues - but I assume the problem does exist.
The ones I have heard it from are in 97-98 Kouki models
Lopin18
240sx Hatch 89 KA24E
Santo Domingo FL
3-1-2007
Might of interest....
How to remove the Flywheel bolts
http://forums.nicoclub.com/zerothread/312477
Unhappy member of over 150 spamming lists after posting my email on Nicoclub sales section ^_^
1989 240sx KA24E @ Dominican Republic
nfp240
1993 nissan 240sx
perry hall md
7-27-2007
good info
Locko
Eagle Talon
Miami FL
2-21-2008
in you dvd it shows how to change the tr
Quote, originally posted by JDS Performance »
hey im thinking of buying your DVD but i would like to know if it would help me swapping my 95 zenki auto SE to a SR20DET 5 speed ? since im changing engine and tranny, does it include the info for this swap ?
JDS Performance
NICO Sponsor
6-4-2006
 « Re: (Locko)
Quote, originally posted by Locko »
this video is on the KA but it however still help you out greatly - as they are in many ways the same.
hammerzone
240SX
Carson
2-3-2008
I'm new to the forum.. here's my question...
I'm going to do swap from auto to manual. My car isa '92 model and the tranny I got is an '89. When buying parts, like clutch set, do I go by the year of the tranny or the current car model which is '92.
Thanks
