ScottManUGA »
https://forums.nicoclub.com/scottmanuga-u121438.html
Tue Dec 02, 2008 5:56 pm
Keep in mind that your brakes are only as good as your tires. If you can lock your wheels with your stock brakes, then you can't stop any faster with better brakes. Better brakes would only prevent brake fade in the case of overheating or constant use.
That said, it's a great upgrade if your stock brakes are shot anyway. Overkill is never a bad idea.
