STLX »
https://forums.nicoclub.com/stlx-u76874.html
Tue Nov 06, 2007 9:58 am
So I've read a bunch of the forums, and I thought I had the problem solved. We've replaced the spark plugs, wires, fuel injectors - and it was still running like crap. We did the self diagnostic with the ECU - and it gave me 34 (knock sensor.)
So last night I replaced my knock sensor, which was cracked as all get out - I started her up and it was still running like crap. It used to bog down in 1st and 2nd, but now it bogs in 3rd. It also sounds like it isnt running on all 4 cylinders.
I tried to reset the ecu just a couple minutes ago, thinking that might fix everything. I disconnected the negative on the battery, and pressed down on my brake pedal for a while ( which everyone said to do.) So hopefully that actually reset it.
I checked the code again, and it still says 34 for the knock sensor. Anyone have any ideas?
